SE Minnesota insanity
Tags: None
Re: SE Minnesota insanity
Looks like the perfect spot to me! Don't tell the neighbors what you're up to... Keep them guessing
Ken H. - Kentucky
42" Pompeii
Cost Spreadsheet ... Picasa Web Album -
Digging the 48 inch deep (below the MN frostline) footings was the last discrete thing about the whole project. Then a truck with a 100 ft boom showed up to blow in the concrete for the hearth tower. After that, although they're still guessing, there was nothing clandestine about this!2 PhotosComment
Nothing too subtle there. I am looking forward to seeing your build -- and your neighbors' reaction.
Good on ya' Eric.
JamesComment
This will be a fun one to watch.
JoeJoe
My thread: http://www.fornobravo.com/forum/f8/j...oven-8181.htmlComment
Yep, the oven will be accessed from within the kitchen--a necessity I feel, when it's -26F around here. The dome will be supported by this tower, which is steel reinforced concrete and is 8 feet above grade. I have a friend who is a skilled concrete tradesman, and we borrowed the mud forms at no cost. It took a day to put them up, and 45 minutes to pour (with the monster boom truck), and half a day to remove the forms. Even after paying my friend his normal wages, buying the mud, and renting the pumper (150 dollars per hour), doing it this way was far cheaper and faster than laying block. The foramen will be about elbow-shoulder height inside.1 PhotoComment
Nice. This is going to be such a cool set up. Have you begun work in the kitchen yet?Comment
Hello, yes. This is what the disaster looks like in the kitchen as of this morning.1 PhotoComment
This is almost as insane as Brett favre leading the Minnesota Vikings to a 6-0 start to the football season!
This ought to be really cool!
Good luck with the build!
~BobMy Oven Progress: http://www.fornobravo.com/forum/f8/p...uild-7155.html
If you fail to plan, you plan to fail!Comment
For the hidden amount of my tax dollars that goes into his 1 million per game, the Vikes better do something right this year!
Finally I am ready to lay the masonry. The FB boards are mushy in areas where they absorbed water from the concrete, so I'm trying to dry them out with a heater. At least the hearth is enclosed now, and I can work through the winter.Comment
Yeah, that's right...2000 pounds of firebrick in one haul. Now how to put these together to make pizzas.........1 PhotoComment
Wow,, very cool.... It will probably take longer to carry the bricks in than anything else..
good luck and keep posting pics
Cheers
MarkComment
Hello All,
Today we nearly completed the (what I call) the "thermal containment area" for the indoor 36". The hearth is 2 inches FB board, 1 inch percrete, and 4 inches structural concrete. The outermost walls are cement board. The dome will be covered by 5 inches of ceramic blanket, leaving an air gap between the dome and the cement board. The hole you see is the outside access door for inspections/repair.
I also started laying out the floor and soldiers. As you can see there is quite a bit of space competition in my little garage. Next week the brick cutting begins in earnest!
Cheers,
Eric3 PhotosComment
