My IT design
  • My IT design
      Has anyone poured cement outside the first course to keep them in place better?
      is this a bad idea?
          Actually, a vcrete or pcrete ring (5 to 1 ratio} around the "full" height soldiers would be advisable as buttressing. There will be quite a bit of horizontal load where the dome meets the vertical soldier. There is nothing wrong with full soldiers it just that builders need to be aware of the buttressing that may be needed. Half height would of been better but you are past that point. It is discussed on the forum quite often. Is this a pompeii or a low dome?
            Pompei. Will do a 20x12” opening. 23” high is expected.
              I have access to vermiculite and I have 3 bags of Portland cement waiting.
              I built the support stand a bit larger than needed. I think I will use the side blocks to form in the vermiculite/concrete.
                Should I trim the insulating board to be flush with the soldiers?
                  63% of the oven height is the recommended opening height. Based on 12" high arch opening and 23" dome height ( I would place the IT in the vertical position to confirm, with the pivot point off the floor) the dome height might be higher) the ratio is 12/23=52%
                  You do not need to trim CaSi board if you are "enclosing" the oven, just leave them proud. If you are not enclosing the oven then you will need to trim CaSi board. It is too late now but we recommend weep holes under the CaSi board, wet insulation is one of the most common problems with poor oven performance.
                  Are you doing a tapered inner arch, it appears that the bricks you have cut show this. It is the best way to match the dome and inner arch. If you are not familiar, then do a search on the forum. But here is a pic showing how the IT works for a tapered inner arch and you have to use full length bricks to accomplish.
                    Thanks Russell. I do appreciate your comments.
                    My IT tool says 23” is the height. So perhaps I should plan on a 14” high opening.
                    Regards
                    David
                      And yes, I think I will do a tapered arch
                        Russell. I don’t see how to search the forum for specific content.
                        David
                          I found the search option!
                            Will This 6 inch chimney be sufficient?
                            (42” Oven)
                            Thanks for responses.
                            David
                              No. See attached Click image for larger version  Name:	chimney.JPG Views:	0 Size:	86.9 KB ID:	417019
