Rocko
glad you are making progress. I wouldn't use treated lumber anywhere. Use metal studs or blocks and put whatever veneer on that that you like (tile, wood, stone, etc.) I covered with cedar and made stone countertops with metal framing. As far as a toekick, i did something similar. I used flagstone that i cut as the "kick" material and gained roughly 1". you could stack and get more if you like. Much easier than concrete. Cut it with a circular saw or 4" grinder and use thinset to mount.
I got 3/8" stainless steel slingshot ammo to tuck under the blocks to make sure I got my 3/8" height. I'd still have to tweak things to make sure I was level. You'll notice a lip on the left side that I did to compensate for some stuff, for example. That's okay since it'll vanish when I pour out the curves for the front. That's going to suck.
