Re: 81 Inch First Build (and first post)
now here is a loooong peel..;
YouTube - abbotsford convent bakery
that is the oven at Abbotsford convent
I plan on fabbing up some tools...but dont forget, we wont bake pizza in the very corners anyway....the space is to keep our options open....we can bake where the temp is the best. I imagine that 75% of the pizza will be in only 50% of the oven...the rest of the space is just to throw it's thermal mass around..so when someone asks "where do you bake pizza?" we can answer..."anywhere we want".
Roger
Tonight we got the soldier course to both sides of the arch..left a space for lighting fixture....only problem is....I don't have one to put in there....thinking of making one up from a toaster oven door and metal reflector..
Roger
- Likes 1
Whoa....That bad boy makes my 60" look tiny. You'll want to fully insulate it so your recovery time is lessened.
...Can't imagine where you are going to find any L O N G peels. That' going to be some unwieldy pie wranglin'.
Man...I'd hate to be your stick man.
The photos with you in them makes me realize how large this oven will be. An impressive project.
Nice................
I got the idea of using the corner cut-offs in a meaningful way from looking at the geo-dome build of dmun's..thanks guy!
Here is my helper staying warm by the fire...it was cold that day..
the soldier/ skew cutting jig
hard "at it"
Roger
- Likes 1
My wife was able to help over the weekend, tending bricks and cleaning up after me...as well as overall inspiration, thanks honey!
the first few soldiers ..the foreground is my center post and frame template....things changed when I lowered the dome height from 36" to 24"
several bricks drying out before going to the oven
Roger
- Likes 1
got the saw working again and set up the jig to cut 90 bricks for the soldier course which will be 8.5 inches tall....using 10 inch brick and cutting the skew angle on the top end..
- Likes 1
Very interesting...and since my brick saw just quit tonight, I have a little more time to work that soldier course height out....ooops..thanks!
Roger
- Likes 1
I'll start with the info then get into my speculation. h=d/3.4 is a simple guideline that has been given to approximate the proper height for a pizza oven. It doesn't give you the shape of the ovens found in Naples which is fairly secret, but it gives you a height that is close to what would be found in one of their ovens. I've seen this posted a few times on line, and have been told it is in a few books of brick ovens in Italy. Now for my speculation. One day while researching arches I ran across a three centered arch. To me it looked like a dead ringer for the sketches I had seen of the cross section of a Naples built oven. On a hunch I opened up my cad software and laid one out. In this type of arch the height is dictated by the width. No matter how wide the arch I found h=d/3.4. This leads me to believe the ovens built in Naples use a specialized shape based on a three centered arch modified to make a soldier course work. They have hundred of years of experience building these ovens in Naples, so I am more then happy to go with what they do....
As for a soldier course I feel they are critical in a low dome oven burning efficiently. This is speculation mixed with the experience I have using my oven and some other feedback. Low dome ovens have much less volume over the door then the high dome ovens that are common here. The higher the soldier course the more volume above the door. I personally think the volume over the door forms a "air cushion" that holds heat in the oven and makes them more efficient. Just a theory...but it my mind atleast it has basis.
Yeah, I've never figured out what the soldier course is for. It's traditional, but to my mind it just makes it weaker. Your huge low dome is going to have a lot of side thrust, and putting it up on stilts is going to accentuate the problem.
Roger,
I built a 42 inch and made it a true radius. My first brick off the deck is 2.5 inches. Granted, I can't push a large piece of burning wood to the edge, but it has never been a problem. I think with your size it would be a non issue.
Les...
shuboyje,
please elaborate on that d/3.4 guideline....give me some background on that..
Hey, everyone....what is the minimum wall height, ie; the soldier course upon which the skew and dome starts? Is 4 to 5 inches too short, or do I really need 8 to 9 inches (full bricks)? I want the shortest wall possible in order to create the highest degree of angle for my 24" dome. The lower I start on the outside rim, the greater the angle to the top. I figure it's just going to be where I push the coals and small wood..thoughts?
thanks
Roger
- Likes 1
81 and 24 is dead on the d/3.4 guidline for low domes. Forge ahead my friend!
