Door handle
  • Door handle
    Lets see some ideas of cool looking door handles.
    i plan on chopping my handle off and replacing it with something that is more insulated.
    Have you checked out the "Show us your door" thread (linked below)? Many different styles that might give you some ideas. Also maybe post a picture of your door so we can see what you want to cut off and possibly how replacement handles might be attached.
    https://community.fornobravo.com/for...read#post17312
    My build thread
      Thanks for the link. I needed to download an app to resize my photos. The forum only allows a 2mb pic
        Constantly have to use a glove.
          I use MS Paint to resize my pics. There are fancier programs out there, but if you are running windows you already have paint. I just click the "resize" button and select pixels. Set the smaller number to 1080 and you will get smaller pics that still have good resolution. Just use the "save as" option so you don't over write your hi-res photos unless you don't want the masters anymore.
          As far as handles go, you are probably going to want to incorporate either some wood or try the wound spring type used on wood stove doors. My handles are wood and I never need gloves, but I do need to make sure the backs of my fingers don't touch the door skin
          My build thread
            These are replacement float handles. In use for almost 3 years now. They work great, no scorching or burning. Always cool to the touch.
            - George
            https://community.fornobravo.com/for...mente-ca-build
              Those are great - have them on both my doors. I can't see the back of his door but it looks like he might be stuck with a welded solution.
              My build thread
                The handle is welded on mine. I think a diamond blade followed by a grinder to touch up the welds will make it flush again. This will give me the opportunity to drill a few holes for a new handle.
                  I have just stainless handles that stay cool to the touch. I also have 4" of insulation installed so I'm sure that helps alot.
                  My Build Pictures
                    I wonder if you can wrap the handles with leather. This way you can keep what you have and not have to take anything apart
                    There is also food grade silicon that you can form up your existing handles and pour the silicone and create a thick coaring that is oven safe. Smooth-sil is one product but there are more out there.
                    Ricky
                    My Build Pictures
                      i have about 1/4” between my door and finger as it is right now when I grab the handle. I can’t add anything else to it right now.
                      Originally posted by Chach View Post
                      I wonder if you can wrap the handles with leather or some type of material. Maybe thin sheet of ceramic blanket to insulate it and leather strips over the top of it or just the leather strips a few layers of it. This way you can keep what you have and not have to take anything apart
                      Ricky
                        what is the purpose of the insulated door? Retain heat longer ?
                          Yes it keeps the heat in longer and surprisingly stays very cool.
                          My Build Pictures
