Hi everyone,
I'm about to order all of the insulating material for my pizza oven. For the floor, I plan on doing 2" Foamglas and then 2" CalSil. For the dome insulation I will do 3" of ceramic fiber blanket. Can you please double check that I am ordering the correct material? There's so many options and I want to make sure the specs are correct.
Foamglas
Compressive Strength : 60 psi
Density : 7.18 pcf
Flame Spread Index : 0
Flexural Strength : 41 psi
Insulation Thickness : 2 in
Item Name : Foamglas Block
Length : 24 in
Material : Foamglass
Smoke Developed Index : 0
Sub Brand : ONE
Temperature Rating : 121 to 800 deg F
Thermal Conductivity : 0.14 to 0.54 Btu-in/hr-sq-ft-deg F
Water Vapor Sorption : <0.2 %
Width : 18 in
Thermo-12 CaSi Boards
Compressive Strength : >100 psi
Construction : Flat
Density : >14 pcf
Flexural Strength : >50 psi
Item Name : Calcium Silicate Block
Length : 36 in
Material : Calcium Silicate
Special Features : Non-Water Resistant
Sub Brand : Thermo-12 Gold
Temperature Rating : 1200 deg F
Thermal Conductivity : 0.344 to 0.647 Btu-in/hr-sq-ft-deg F
Width : 18 in
Blanket
Color : White
Density : 8 pcf
Insulation Thickness : 1 in
Item Name : Ceramic Fiber Blanket
Length : 25 ft
Material : Ceramic Fiber
Series/Model : Durablanket S
Specific Heat : 0.27 Btu/lb-F
Sub Brand : Fiberfrax
Temperature Rating : 2300 deg F
Tensile Strength : 7 psi
Width : 24 in
For those that ordered through Distribution International, how was your experience? Seems like they only work with contractors/businesses and not your typical DIY guy.. but I could be wrong.
Anyways, thanks in advance for your help!
Foamglas
Density : 7.18 pcf
Length : 24 in
Sub Brand : ONE
Width : 18 in
Construction : Flat
Density : >14 pcf
Length : 36 in
Width : 18 in
Blanket
Color : White
Density : 8 pcf
Length : 25 ft
Width : 24 in
