After I promised a friend that I'd cater his wedding at my place with a WBO I need to build it in only a couple weeks! Drawings attached, feedback please!! (Google Doc) Frame and Hearth PIC
Technical Drawing and Cut List
Solid Works Ass.
The Plan:
-36" Forno Bravo Pompeii Kit
-1.5"x 0.125wall Steel frame (Attached Solid Works Drawing of geometry)
-59" x 64" x5.5" hearth poured at the same time as the pad
-build oven on steel frame in garage
-Low vault Tuscan igloo (Modified IT with lazy susan)
-Slow dry the oven in the garage with woodstove lit, yes during the summer.
-use backhoe to move hearth & oven into place once pad and oven are completely dry
-Series of drying fires
I have some masonry experience,
Out of my mind to try this in 3 weeks? is likely that I'll be able to move the hearth/stand/oven without cracking everything?
Solid Works Ass.
The Plan:
. But I digress , anyone have experience building on a metal stand and moving dryed oven? Tips suggestions? I haven't applied the weight to the stand in SW but based on some stands I've seen this one should be over built. Feedback? Plus adding 0.188 wire loops welded to the top of the stand to hold the concrete on the stand in transit and for eternity
