Re: Rockland County, NY 36" build with pictures.
Thank you all for the good advice. Explain a little more about these "through bolted kickers" Tscarborough? I can't quite picture them with my limited knowledge.
Also thanks, Mikku for the advice. It may not be clear, but the inner of the two joists on the long edges are held up with metal hangers attached to the posts. Do you still think I need notching?
If the picture isn't clear, I was trying to highlight the small spot that you can see the metal hangar peeking out. It's the kind of hangar where the flanges fold inside, commonly used for joists attached to the very end of a deck ledger board.
Concrete pour day is Friday, weather permitting. A friend is available that day to help me lift concrete into mixer. Can I do it in a slight drizzle, weather speaking?
Online calculators calculate 10-12 bags of concrete for a 4 inch slab, about 20 square feet. My slab will be about 22 square feet, but only 3.5 inches thick. Speaking of that, do I do the 3.5 inches in addition to the 1/2 inch hardibacker board? Or do I include it in the total?
