36" build in Tallahassee - AKA Bruce's Folly
1 PhotoOld World Stone & Garden
John Ruskin
Re: 36" build in Tallahassee - AKA Bruce's Folly
Wow, that is amazing, it matches the granite and is very smooth. What was in your slurry and was that applied in multiple layers?Originally posted by stonecutter View PostWorked well Bruce, you should have no trouble with this.
[ATTACH]37395[/ATTACH]Link to my build here:
http://www.fornobravo.com/forum/f6/3...lly-19181.html
Selected pictures of the build.
https://picasaweb.google.com/1168565...g&noredirect=1
sigpic “In theory, theory and practice are the same. In practice, they are not.” ― Albert Einstein
Just Portland and a diluted acrylic mix....9:1. That is two light coats...keep a bucket of water and a sponge handy to remove the slurry off the brick as you work.Old World Stone & Garden
John Ruskin
Lowes has QUIKRETE Concrete Acrylic Fortifier (Shop QUIKRETE 2 lbs Concrete Acrylic Fortifier at Lowes.com). Is this correct?Originally posted by stonecutter View PostJust Portland and a diluted acrylic mix....9:1. That is two light coats...keep a bucket of water and a sponge handy to remove the slurry off the brick as you work.
Also, I understood your instruction to be a mix of opc and acrylic (no water). Just checking. Is the 9:1 ratio 9 parts opc to 1 part diluted acrylic?Link to my build here:
Oops...no 9:1 was the dilution ratio of the liquid..9 parts water, 1 part acrylic.Originally posted by Bec1208 View PostLowes has QUIKRETE Concrete Acrylic Fortifier (Shop QUIKRETE 2 lbs Concrete Acrylic Fortifier at Lowes.com). Is this correct?
That quickcete brand is different than what I have, just cut it by 50% and that will be fine.
As far as what quantity of opc to add..it's not critical. If you make the slurry like a milkshake, you're good. You just want to make sure there is enough porty to coat the insulation. If it is stiffening up just add a splash of cool waterOld World Stone & Garden
John Ruskin
Thanks, should be able to try out this afternoon. I finished up the smoke chamber yesterday.Originally posted by stonecutter View PostOops...no 9:1 was the dilution ratio..9 parts water, 1 part acrylic.
As far as what quantity of opc to add..it's not critical. If you make the slurry like a milkshake, you're good. You just want to make sure there is enough porty to coat the insulation.2 PhotosLink to my build here:
I have a fig tree too. We make a pizza with green figs, blue cheese and prosciutto.
Gives you an idea what to use those figs for...I'm assuming you need to trim back the tree for chimney clearance...but maybe that's a depth misperceptionOld World Stone & Garden
John Ruskin
Yes, it is overhanging. There's a bumper crop coming in right now thanks for the topping idea. Do you put a sauce on the fig pizza?Originally posted by stonecutter View PostI have a fig tree too. We make a pizza with green figs, blue cheese and prosciutto.
Gives you an idea what to use those figs for...I'm assuming you need to trim back the tree for chimney clearance...but maybe that's a depth misperceptionLink to my build here:
Well, sort of. My wife makes a balsamic reduction...no red sauce on this one, but we do put just a little mutz on there, more for texture.Old World Stone & Garden
John Ruskin
Like the idea of the reduction, will have to try. Ended up at Home Depot and picked this one up.Originally posted by stonecutter View PostWell, sort of. My wife makes a balsamic reduction...no red sauce on this one, but we do put just a little mutz on there, more for texture.1 PhotoLink to my build here:
Sika makes excellent products.Old World Stone & Garden
John Ruskin
Oh, that is a nice pizza. I like to add a little arugula on top. FYI - Trader Joes sells a balsamic reduction in a squeeze bottle, if you have that chain in your area.Originally posted by stonecutter View PostI have a fig tree too. We make a pizza with green figs, blue cheese and prosciutto.
If you find yourself in a Canadian store look for balsamic cream. It's fabulous! When we're in Canada and ask for balsamic reduction normally they don't know what it is...the same is true when you're in the states and ask for balsamic cream. As far as I can tell they are the same product, just that potato/potatoe thing I guess. We picked up a white citrus flavored balsamic cream in Vancouver B.C. and used it as a "drizzle finish" on a cedar planked salmon from the WFO...really nice. Also worked well with lobster tails and shrimp from the Tuscan grill in the oven.Originally posted by deejayoh View PostOh, that is a nice pizza. I like to add a little arugula on top. FYI - Trader Joes sells a balsamic reduction in a squeeze bottle, if you have that chain in your area.Mike Stansbury - The Traveling Loafer
Roseburg, Oregon
They are in the midst of building their first store. Should be opening in a few months. Thanks for the tip.Originally posted by deejayoh View PostOh, that is a nice pizza. I like to add a little arugula on top. FYI - Trader Joes sells a balsamic reduction in a squeeze bottle, if you have that chain in your area.
Well I have 3 coats of slurry applied now. I added a small amount of terracotta cement color because I thought it would blend better than grey.1 PhotoLink to my build here:
Salmon sounds great. Can you describe the technique (temp, fire, ect...) Thanks, BruceOriginally posted by SableSprings View PostIf you find yourself in a Canadian store look for balsamic cream. It's fabulous! When we're in Canada and ask for balsamic reduction normally they don't know what it is...the same is true when you're in the states and ask for balsamic cream. As far as I can tell they are the same product, just that potato/potatoe thing I guess. We picked up a white citrus flavored balsamic cream in Vancouver B.C. and used it as a "drizzle finish" on a cedar planked salmon from the WFO...really nice. Also worked well with lobster tails and shrimp from the Tuscan grill in the oven.Link to my build here:
