Re: Finally started
Thanks John. It is mostly refractory cement which is how I got the close joints. The thickness is supposed to be no more than 2mm with what I was using. The walls and the vault are done with this, but I needed something a bit more forgiving with the front bricks coming down at the front, therefore used home brew. I had some left over, therefore just put a thin layer over the top of the vault rather than throwing out. Guess I should leave it a couple of days or a week if I can. Maybe next weekend.
Regards
Mark
Regards
Mark
