Work of Love and Passion... Miami FL
  • #16
    Re: Work of Love and Passion... Miami FL
    Thanks David, I will follow your lead, I just saw your built and you were cooking roast beef the next day of the fire and bread and cookies and that is the same thing I want. Love it, thanks for the comments.
    Best Regards...
    Gugahulk!
    My Build...
    http://www.fornobravo.com/forum/f6/w...-fl-21793.html
    BUILD IT AND THEY WILL COME
    Food will always be the best way to spend time with family & friends, and that is all that really matters.
    STOP THINKING ABOUT IT AND DO IT!
    • #17
      Originally posted by DavidApp View Post
      Hello
      You have a great looking cooking area there.
      One suggestion is to make sure you have room behind the dome to get the blanket and covering layer on. I thought I had plenty of room but have resorted to stuccoing the back section of my oven by hand. Stucco mix applied hand full at a time because there is not enough room for a trowel.
      Someone in the group mentioned it before I started. I checked and thought there was plenty of room.
      Spend time reading the various build threads. There is a wealth of knowledge to mine.
      Insulate. Insulate. Insulate.
      My oven is still over 150 degrees having fired 4 days ago.
      David
      Here's a solution I've used on a few ovens that are too close to a wall.
      http://www.fornobravo.com/forum/f9/t...tml#post187002
      • #18
        Hello
        Your support walls appear to be 36" apart and about 20 to 25" tall. I am not sure how far you can span with the slab but if necessary you can build some beams into the slab to help with the span.
        Most of us probable way overbuild just in case.
        I used the 5000lb Quikrete for my slab which is 5" thick.
        You need to consider the finished height of the oven floor. I am 5'9" and my floor is about 43" which is a nice height to work the oven but the entry arch does obstruct my view a little so the floor could have been 2" higher. I have to stoop a little to see in to the back of the oven.
        I was in Italy last year and looked in an oven there. As far as I remember the floor was a bit higher than my floor. Like everything on the oven it is all a compromise.
        David
        • #19
          Thanks David, this is a great tip.
          Best Regards...
          Gugahulk!
          My Build...
          • #20
            Hello
            David
            Thanks DavidApp, So you are recommending me to use the maximizer right? I don't want it to fail
            About the height its now 36 inches high and I plan it to be when all done the floor of the oven should be about 46 inches in height. I am 5'10" so I think its ok. What do you think? Here is a picture of the final base ready for concrete.
            Best Regards...
            Gugahulk!
            My Build...
            • #21
              Hello
              I am not familiar with that brand but you should be OK with Maimizer as it is a 5600lb mix.
              The cooking floor height looks good. If it is too low your view will be obstructed and if it is too high working the oven will be harder.
              I am keeping a record of my oven temperature so that I will have a better idea when to schedule my cooking.
              David
              • #22
                Hello
                David
                Awesome thanks, yes let me know about the temperature, look forward to knowing it.
                Best Regards...
                Gugahulk!
                My Build...
                • #23
                  Little lost about the insulation board. Try to find a thread but didn't. How do I attached the insulation board to the concrete slab? with nothing? it just sits on it? How is it glued on the slab?
                  Also I plan on using the firebricks right on top of the insulation board, is that the best way? should the walls of the oven be layed directly on the concrete slab or better in the insulation board? Any input would be appreciated.
                  Best Regards...
                  Gugahulk!
                  My Build...
                  • #24
                    Hello
                    The Insulation should go on a vapor barrier. It just sits there held in place by the weight of the oven.
                    The Fire brick go on a layer of fine sand/fire clay mix to level the bricks. The same as you would lay pavers.
                    The Oven walls should also go on the Insulation. You can either have the walls sit on the floor bricks or on the insulation. Both ways have advantages and disadvantages. If the walls and floor are separate you can replace floor bricks if they get damaged.
                    This is my temperature profile early version. The blue line is with a 2" door the red line is my new 4" door.
                    David
                    • #25
                      First --- Everything hot should only touch insulation. And to be safe cut your insulation board about 1 inch larger than the outermost bricks of your oven (if possible).
                      Second Gravity holds the board in place. Once you put 1000 pounds of brick on it. Well let's just say it would be difficult to move.
                      Third. Level your firebrick with a thin layer of fine sand and mixed with fire clay if you like. Use a notched trowel like used for tile work to allow you to easily level the bricks.
                      Do not mortar under the first row of dome bricks. Also place a spacer of corrugated cardboard between dome and floor to provide an expansion gap. The cardboard will burn out and fill with ash over time.
                      I am not sure I agree with the vapor barrier comment above unless it was a piece of thin stainless steel. Iron/steel will rust, and other materials well ... there is still a great deal of heat nearby. Your slab should be kept dry from the outside and if you have moisture in your slab that needs a vapor barrier you have other problems.
                      I do agree that your stand and the slab under the oven should have a vapor barrier but that is in a cool area and prevents wicking from the ground.
                      Chip
                      • #26
                        David
                        Did you leave the door in place for the whole test of the charting?
                        Was the wind and outside temp about the same for the duration of the test?
                        Chip
                        • #27
                          Hello
                          David
                          Wow this is valuable information, thanks. I am not able to find fireclay any where, can I just use play sand from home depot?
                          The vapor barrier how should I ad that?
                          So my oven will not be attached at all to the base, it will be completely help down by its weight. Only once I stucco it and it will be permanent correct? The vapor barrier is between the side walls of the oven and the floor of the oven? I need to understand this better as I don't understand why. Thanks again this never crossed my mind.
                          Best Regards...
                          Gugahulk!
                          My Build...
                          • #28
                            Play sand is to coarse. HD has fine sand just ask for it.
                            Vapor barrier. Simply plastic 4 mil is fine. Sold as drop cloth plastic in paint department as sheets or large rolls for vapor barrier in construction. Place on top of your stand just before you pour your slab.
                            Reason for vapor barrier is that moisture will wick up through the concrete in contact with the ground and cause the slab under the oven to become damp, this moisture will reduce the efficiency and insulating power of your ceramic board.
                            For this reason you also want to waterproof the top of the slab your oven sits on so rain does not penetrate that slab.
                            Pay particular attention to waterproofing the seam that will exist between the oven and the slab. It is a common location for rain to seep in.
                            Look at the drawing again. Corrugated cardboard between oven wall and floor.
                            Chip
                            • #29
                              First of all thanks for this! Grateful for this knowledge, question why whould I put a vapor barrier of cardboard under the slab? than the slab it self will not be attached the the bricks. Did I understand this correctly? There should be no heat at all there.
                              And the first layer of bricks on the dome and floor of the oven will not have any motar at all? I understand replacing the bricks on the floor of the oven but how would I ever replace the side? unless there is another reason for it doesn't make sense to a novice like me. Sorry for the question... and thank...
                              Best Regards...
                              Gugahulk!
                              My Build...
                              • #30
                                Wow, you are very helpful, I really appriciate the comments. I hope to one day meet you here in miami, love to take you fishing and test the oven once all is done. Some fishing pictures below maybe you have an excuse to come down one day...
                                Best Regards...
                                Gugahulk!
                                My Build...
