Re: Well i quess im building an oven!
You have two choices, pour a slab on a well-drained bed of crushed stone, in which case your excavation should be fine, or to dig down below the frost line, and pour footings on undisturbed soil, and build your structure up from there.
The first choice should be fine if it's a free-standing oven, without a tall masonry chimney.
You should put that as your quote line.
