I made a simple curved trowel to set my pcrete which I used 8 to 1 doing the layers in 4" lifts.
Mobile Oven Dome in MIchigan
Finished my curing fires today. After reading tons of posts on curing methods and timing I decided on the following.
Day 1 - two chaffing dish fuels for 6 hours - high temp 120 F
Day 2 - four chaffing dish fuels for 6 hours - high temp 200 F
Day 3 - turkey fryer burner on very low for 8 hours - high temp 300F
Day 4 - turkey burner on med for 8 hours - high temp 500 F
Day 5 - wood fire for 6 hours - high temp 700 F
Day 6 - wood fire for 5 hours - high temp 1,000 F
This seems to have worked pretty good. I plan to do a cooking fire tomorrow....Comment
Hi Utahbeehiver,
Thank you for the great info you contribute to this great forum.
How long did you hold the curved trowel to set my pcrete?
Also, I am planning to have a 8" pcrete ( approx. 20cm), Is that doable with the 8 to 1?
My pcrete is going to be vermiculite mixed with large pumice stone, do you think 8:1 is workable?
Held trowel until pcrete would not fall away, less than 60 seconds if I recall but I did not do 8" thickness, more like 3" so I cannot say how long 8" will take but you will need to do it in vertical lifts so it does not collapse vertically as well. 8 to 1 is what I used but can't say how pumice will affect workability or insulation factor.👍 1Comment
I finished my oven in August and have been burning cooking fires to dry out the render before I do my final coat which I think is going to be paint but could possibly be a colored, watered down product that David has talked about that can be brushed on.1 PhotoComment
One issue I am having is my chimney...I am using a 8x8 clay flue (I like the look). It is removable so I can store it when I travel. However, the flue is cracking. I believe this is because of the temp variance between the inside of the flue and the outside...especially on cool nights. Has anyone ever insulated the flue in a way that was attractive? Could I get way with using a flue blanket just until it warmed up and then leave it bare after heating the oven? Thanks for any thoughts.Comment
