Modified 3G Masterly Tail Build
  • Mitchamus
    • Aug 2008
    • 389
    Hi Guys,
    This will be a build thread for my modified 3G masterly tail oven. (my 2nd oven build)
    This is a vault oven design, which will incorporate more insulation and less thermal mass than the proposed design by Rado.
    I have already built a Swishy oven back in 2008, and am very happy with it apart from the long heat up time, but really like the extended cooking period.
    I was all in for building a dome oven for this build, but after using my brother in law's 42" dome oven - I was fairly underwhelmed with it's performance both for baking/roasting and pizza over the Swishy.
    I know some people swear by the dome style, but I found that the floor performance (50mm tile over insulating bricks) lost heat far too quickly (it could not bake multiple pizzas in the one spot to my liking)
    and when it came to cooking a roast dinner, the heat loss from roasting temp dropped off far too sharply (for me), and it took way to long to finish. (YMMV)
    I would also like to be able to make pizza at night, and bake bread or roast meat the next day without having to re-fire the oven.
    anyways - I'm not looking to start a discussion/argument - just trying to explain my reasons why I have decided to go with this design, so as not (hopefully) to be bombarded with posts about "why not build a dome"
    you probably disagree with my reasons or probably want to question my oven usage techniques - that's ok/cool - but lets hope for an 'each to their own' mind set.
    so anyways... onwards to the build...
    Here are some shots of the base slab going in. I will be putting up the stand over the weekend, so some shots of that to come next week.
    My 2nd Build:
    Is here
  • Mitchamus
    • Aug 2008
    • 389
    Re: Modified 3G Masterly Tail Build
    5th image in new post due to 4 image limit...
    My 2nd Build:
    Is here
    • Mitchamus
      • Aug 2008
      • 389
      could a Mod please move this thread to 'Brick oven Photos'
      I have posted in the wrong spot...
      My 2nd Build:
      Is here
      • deejayoh
        • Jul 2010
        • 1893
        you're in the right spot. If you post in photos, you won't get many comments.
        Curious, do you have any pictures of a finished oven of the type that you're building?
        • Mitchamus
          • Aug 2008
          • 389
          only from the plans, (which I won't re-produce here due to copyright) but here is one available online.
          mine will not look like this though
          My 2nd Build:
          Is here
            • 2848
            Gudday
            I don't think anyone here is worried about it detail of size or detailed plan. But just how its configured wood be interesting. Is it a dome , a barrel , made if insulated. You are a member of the forum and the forno plans are free it you would like to compare
            • Mitchamus
              • Aug 2008
              • 389
              Thanks Dave, yeah I have looked extensively at the forno plans - most of my mod ideas have come from reading on this forum since 2008.
              It's a barrel vault design, pic from Rado's site:
              (deleted - people keep thinking this is what I've built *shrug*)
              the hearth bricks will sit on edge on, giving a floor thickness of 115mm, on top of a full 4" of perlcrete insulation above the hearth slab.
              The whole vault will be skinned with only 2" of cladding, Then the walls insulated with 4" of loose Perlite and the vault top covered in 2-3" of blanket insulation. (this will also allow me scope to add more cladding if I need it)
              I'll also change the chimney design somewhat to make a smaller landing than the original design. The chimney will be thermally separated from the oven cladding by 4" of perlcrete and any blanket I have left over stuffed into any air gaps.
              My 2nd Build:
              Is here
                • 2848
                Gudday
                Interesting to hear your comments on the 50 mm floor tile.
                I have firebrick set on 75 mm edges and find them to store a goodly amount of heat. Multiply pizza are not a worry and baking next day is never an issue as long as you close the oven of with an insulated door. I toyed with the idea of doing the brick at 115 mm edge but decided in my case it was overkill as I didn't see myself doing multiple bread bakes and such.
                I think you'll find that most members here have no problem with whatever configuration you us ... You'll only get some comments on lack of insulation or other thugs that make a WFO unusable
                • brickie in oz
                  • 3445
                  200mm of thermal mass in the floor? Really?
                  • Mitchamus
                    • Aug 2008
                    • 389
                    Not sure where you got 200 from- but it would be 115mm
                    (Btw swishy has 215mm and will easily hold 500deg C + all day long)
                    My 2nd Build:
                    Is here
                    • brickie in oz
                      • 3445
                      Prolly from the brick on edge and the thick concrete underneath it.
                        There is insulation under the floor bricks, so it could hardly be considered thermal mass.
                        • Mitchamus
                          • Aug 2008
                          • 389
                          ok so made a fair bit of progress on Saturday - Got the stand put up and filled with concrete.
                          The blocks were on the terrible side of 'pretty crap', and I was chasing plumb & level with every course.
                          One fell apart in my hand when I picked it up. I guess they are using the bear minimum amount of cement in them to maximise profits.
                          Some of them were different heights left to right, and the faces weren't straight on a lot of them.
                          From here on up, the sides will be finished with 1/2 width blocks - If I get these blocks from the same supplier, I will mortar them in from now on.
                          This stand be rendered/painted/skinned with stone (haven't decided yet) so it doesn't have to look amazing, just be structurally sound.
                          My 2nd Build:
                          Is here
                          • Mitchamus
                            • Aug 2008
                            • 389
                            I made a dent it the Hearth slab formwork on Sunday morning too.
                            My 2nd Build:
                            Is here
                            • Mitchamus
                              • Aug 2008
                              • 389
                              I have managed to source some 2nd hand insulating fire bricks to make a thermal break between the oven vault and the chimney.
                              They are in pretty poor condition, but they will be in the back of the chimney, and I'll use the best ones in the spots that can be seen, or perhaps cut them to clean the faces up a bit.
                              My 2nd Build:
                              Is here
