Modified 3G Masterly Tail Build
  • Mitchamus
    • Aug 2008
    • 389
    #46
    Re: Modified 3G Masterly Tail Build
    Um- the bricks are 3" not 4- same as a Pompeii, but with an extra 2" of cladding- as is recommended in the Pompeii plans. When I say extra thermal mass, I don't include the firebricks in that as it's 'extra'
    You seem to be having a hard time comprehending what I'm doing. I don't know if you have a problem there or not, but it seems you just can't a grasp of what's going on.
    I'm not intentionally trying to be rude or anything, and this is the last reply I'll make to you regardless of what you reply in return.
    But- thanks for your input so far, but perhaps you time would be better spent helping someone else?
    No hard feelings...
    My 2nd Build:
    Is here
      Mitchamus,
      From your recent pics it looks like you intend to build the vault on top of the end walls. This is recommended practice for a barrel vault in kiln building. If the end walls are outside the vault when it expands with heat it puts pressure on those end walls, pushing the them out.
      Although the temperatures we fire to are around half that of a kiln and the resulting expansion correspondingly less, the principle still applies for a WFO.
      Dave
      • Mitchamus
        • Aug 2008
        • 389
        #48
        Hi Dave,
        The plans call for the vault arches to be built inside the back wall, rather than on top, but the whole vault is encased in 2" of reinforced concrete.
        The rear wall bricks are just dry stacked, and not bonded to the vaults, so there can be a little bit of wiggle room there under expansion.
        cheers,
        Mitch.
        My 2nd Build:
        Is here
          Originally posted by Mitchamus
          Hi Dave,
          cheers,
          Mitch.
          OK, follow the plans then.
            • 2848
            #50
            Gudday
            I just thought I'd point out that brickies oven is not a dome but a barrel oven. It would be worth it to check it out. It is his secound oven and it makes an interesting read and you can figure out his position on ovens
            • Mitchamus
              • Aug 2008
              • 389
              #51
              Gudday
              Hi Dave, yeah I've read his build - this is my second vault build as well.
              you can see some of my first oven pics posted in my photo album, but I never did a build thread on it or anything.
              pics are here:
              http://www.fornobravo.com/forum/memb...oven-pics.html
              My 2nd Build:
              Is here
              • Mitchamus
                • Aug 2008
                • 389
                #52
                OK so the bulk vault is done, all that is left to do is to close it in.
                It came out ok, but for some reason, everyone decided to come and talk to me that day, and having been distracted, and with the stopping & starting - it is not as perfect as I would have liked it to be. One of the vault bricks slipped down a few mm and so doesn't line up with the rest.
                I now have to decide whether to live with it, or to remove one of the vaults and fix it.
                It's not an easy job to fix, and will be quite awkward and time consuming to do.
                Structurally it's completely sound, it's just an aesthetic thing. I could probably live with it... but you can see it, and it will probably annoy me everytime I look in there.
                My 2nd Build:
                Is here
                • Mitchamus
                  • Aug 2008
                  • 389
                  #53
                  My 2nd Build:
                  Is here
                  • Mitchamus
                    • Aug 2008
                    • 389
                    #54
                    You can see the offending brick here.
                    Problem is - I didn't notice until I was finished.
                    I think I might be able to put the form back in, and chop out 3 to 4 bricks from the right side, and then re-lay them.
                    Cutting them out is going to be a PITA though, and I also risk ruining the rest of that row in the vault.
                    I was thinking I would cut the mortar out from the outside with a diamond blade on an angle grinder, and tap what's left out with an old flat bladed screw driver as a mortar chisel
                    Once most of it was out, then tap them each brick out from the inside with a hammer and wooden drift.
                    But with the form work back in there holding up the rest of the arch - it's going to be very hard to tap the first brick out from the inside.
                    I think it will annoy me too much to live with it though....
                    My 2nd Build:
                    Is here
                    • SableSprings
                      Moderator
                      • May 2009
                      • 1310
                      #55
                      Would simply taking a grinder to that "slipped brick" work? If you grind the edge back so it's a smoother transition it will be much less noticeable. Especially when you close...you certainly won't be able to get the same look down the barrel when the front bricks & door/entry/landing are in place. It seems to me that your plan to "pop out" the offending brick is truly going to be the PITA you envision.
                      I know we all have those little things that bug us, but 10 minutes of grinding & an adult beverage would work wonders on the "bug". By the way, I think your barrel build looks fabulous! Looking at your first pizza on the hearth will also keep you from focusing on a little irregularity in the vault.
                      Roseburg, Oregon
                      • Mitchamus
                        • Aug 2008
                        • 389
                        #56
                        Grinding it certainly would be a much easier option.
                        It doesn't look so bad in the photo - it looks much worse in real life
                        My 2nd Build:
                        Is here
                          Was there a reason you didn't stagger the joins on the vault?
                          • wotavidone
                            • May 2011
                            • 800
                            #58
                            You aren't really going to risk wrecking it all for that one brick, are you?
                            • stonecutter
                              • Jun 2007
                              • 2003
                              #59
                              Yup. Feather out the lippage..no real need to remove it
                              It is always better to bond courses but it's not as critical for something like this.
                              Old World Stone & Garden
                              John Ruskin
                              • stonecutter
                                • Jun 2007
                                • 2003
                                #60
                                BTW, I like the radius of the arch.
                                John Ruskin
