Hey everyone
So a 2 years ago I decided to build a cast homebrew oven. I made it on a wooden structure because I was living at a rented place and, though I expected to live there at least five years.
Link to the original build is attached.
I got got it insulated and fired it one time before fall came, but I did have steam coming off it once during the firing process though I tried to actually go slower than every guide I could find. I packed it up for the winter. Last year some things changed, and we bought a house. My brother in law works as a fork lift technician, so he was able to borrow a massive trailer and a fork lift, so I was actually able to have it moved to my new house.
Now I have a cack in it. In the inner dome from the front opening and maybe 2/3 back. There is also a Crack ind the outer dome, so I actually have some smoke coming out when starting a fire.
What would you suggest I could do from here? I figured I would remove the insulation around the Crack and replace that and then when everything is dry I would render it. I would just let the Crack in the inner dome be and then be more careful when I eventually upgrade it.
Any tips are greatly appreciated.
