Re: 28" Pompeii
Gene, you're going through exactly what I did. My mortar seemed dry and grainy and not that easy to work with. I messed with the sand/fireclay ratios in an effort to get a more pliable mortar. Things didn't improve. I inquired about this with Tom (tscarborough) and he explained about using the correct sand grain size for the size of joint you are using. He said to 'build' your mortar aggregate 'mix' using varying sand sizes in order to minimize the volume of Portland cement needed which reduces the potential for shrinking and cracking. His analogy was the jar filled with marbles, sand and water.
I was gifted 400lbs of 120 grit fine silica sand and the difference was like night and day! The mortar is smooth and buttery, not gritty, and a joy to use. Because my joints are small I elected not to add any larger-grain sand. Interestingly, up to now the dome has been largely built in cool, damp weather (no cracking) but recently the day temps have climbed into the 80's and the quicker dry times have revealed a few super-fine cracks. Try a smaller (30/60?) grain size, consider blending, and cover your latest work with a damp towel if it's warm.
