Jim's Build for the Common Man
  • deejayoh
    • Jul 2010
    • 1893
    #91
    Re: Jim's Build for the Common Man
    Originally posted by jimkramer
    Deejay, I tried a wetter mix, and it is easier set the bricks. But doesn't that make the mortar weaker?
    If the water is soaking into the bricks almost immediately, then no. Try lifting up a set brick, you will see it gets dry in a hurry.
    • jimkramer
      • Jun 2009
      • 143
      #92
      Getting close with the dome. Probably 3.5 courses, then the cap. Bricks are really starting to get vertical. I'm mixing the mortar a bit thicker now, to help them stay up, and so it doesn't all slide out of the inverted V's. I made a hook, idea stolen from someone else, with a brick tied to it to keep the dome brick in place while it's setting up. Works like a charm. My twist was to use clothing hangars.
      It's getting hard to contort my body to look on the dome side to see if the voids are filled in. Not sure how I'll do this for the last two courses. I guess I got to slide into the oven again. I went in there to fill voids shown in one of the pics.
      I've been using half and third bricks. It's getting very hard to avoid lining up the breaks (stay on bond?), but I think it's good enough. I have to say, the whole think is looking not too bad. Better than what I would have said was the bottom rung of acceptable when I first started. Doesn't seem to be a droop over the arch. And I'm amazed the courses are circular, and level. Guess my bare bones IT did it's job.
      Here's mine:
      http://www.fornobravo.com/forum/f8/j...man-15992.html
        • 2848
        #93
        G'day Jim
        Great to see how your progressing. Your not wrong about about keeping that circular right to the last ....well done. In fact you have ticked a lot of boxes now.
        Arched oven mouth.....tick
        Arch to dome transition....tick
        Still level and circular over the arch.... Tick
        Keystone....under construction....can't wait!!!!
        • jimkramer
          • Jun 2009
          • 143
          #94
          Thanks, Dave! Feels good to get some props from a few continents away.
          Here's mine:
          • jimkramer
            • Jun 2009
            • 143
            #95
            Dome getting close, so I'm thinking more about the vent arch. Is it necessary to insulate underneath? I"ll have an insulated heat break, so I would think the bricks on the vent side of the break will let their heat escape up the chimney, regardless of what insulation is underneath. Or will they transfer more heat from the oven if there's no insulation?
            Here's mine:
            • GianniFocaccia
              • Jun 2009
              • 1645
              #96
              Hey Jim,
              Nice progress, and looking good! It won't be long now!
              As long as your heat break is complete (separates the oven and floor) you should be good to go. Still, 2-3" of vermicrete under the entryway couldn't hurt...
              • jimkramer
                • Jun 2009
                • 143
                #97
                Thanks, GF
                Not sure what you mean by the break separating from the floor. So I have my oven sitting on 4.5" of cal sil. Directly in front of that I had planned to pour a small slab, 4.5" of concrete so that the floor bricks of the vent will be level with the oven floor. In between the vent floor and oven floor I'll have a .5" heat break (ss tube maybe filled with kaowool caulk or rope) Are you saying the vent floor bricks need to be separated from that small slab I'm gonna pour? I guess I could just put down another 1.5" of cal sil, since I got it.
                Here's mine:
                  • 2848
                  #98
                  G'day
                  Most folk insulate under the entrance hearth because it doesn't
                  Hurt and it gives you the same level all the way through.
                  Disadvantage is though that insulation goes right back into you oven and provides a path for any rain that falls on you hearth brick to wick back into your oven. Insulation soaks up moisture real fast. I have had to fashion an outer door to stop this happening. But if your oven entrance is fully
                  Protected go for it
                  • GianniFocaccia
                    • Jun 2009
                    • 1645
                    #99
                    Disadvantage is though that insulation goes right back into your oven and provides a path for any rain that falls on your hearth brick to wick back into your oven
                    Wise words. When you pour your entryway slab, slope it a few degrees away from the mouth of the oven and top directly with your insulation and bricks.
                    I too had planned to go with a stainless tube between entryway and oven floor, but changed my mind and instead went with a 1/4" air gap. This gives me a 1/4" heatbreak all the way around my entryway and floor, which means my entryway is completely standalone. Even after a five or six-hour pizza session, the lower and outer entryway bricks away from the oven are cool enough to lean against. I feel the heatbreak (especially between floors) is most effective once the oven is put to rest, since during normal oven operation the flow of air over the entryway floor is into the oven.
                    • jimkramer
                      • Jun 2009
                      • 143
                      #100
                      Okey doke, makes sense. I'll go with at least one layer of cal sil under the vent, or maybe make the slab out of vermicrete. Great idea to slope the entry floor. I hadn't thought about rain seeping in. I guess that's one of those things you usually learn after it's been built.
                      Another night session has helped me get even closer, and help me feel less like an absentee father. Mixing the mortar a bit thicker and using the hook/weight has kept any bricks from falling. A thicker mix also keeps mortar from falling out from the inverted V's when I put it in place. I figure I have one more course, then I can cap it. I used 1/3 bricks for this last one, think I'll switch to 1/4's.
                      How crazy do I need to get about filling in voids? I suppose, as I'm in the North East, freezing of moisture could be an issue. Luckily I'm not claustrophobic, but it ain't comfy squeezing into the dome. Reminds me of getting an MRI.
                      Glad I was finally able to get a wildlife shot.
                      Here's mine:
                        • 2848
                        #101
                        G'day
                        Of course you'll go with those 1/3s and 1/4s but don't forget those 2/3 and 3/4 can come in handy as well to bridge those gapes and make sure that the mortar gapes don't line up
                        • jimkramer
                          • Jun 2009
                          • 143
                          #102
                          RIght, actually, I have been using a combination of all sizes to keep the breaks from lining up, and to keep it in circle. But I can see for this course overall, they have to be narrower.
                          Here's mine:
                          • jimkramer
                            • Jun 2009
                            • 143
                            #103
                            Ouch!
                            Cement burns. No progress on dome, just wanted to post this pic. Cortisone creme helped a lot with the sting.
                            Here's mine:
                              • 2848
                              #104
                              G'day
                              Wash your hands in ordinary vinegar first, takes away the string immediately. Will not cure the damage however, but that terrible itch is gone
                              • GianniFocaccia
                                • Jun 2009
                                • 1645
                                #105
                                I didn't believe the vinegar cure when I first read about it here back when, but I tried it and it really works.
