Re: Chip's 42 in Minnesota
Yes I used the fixed length IT to mark the brick insides to match the dome inside and the string was used to mark the angle of the sides I'd the brick. I marked the string where the outer dimension of the dome came to and was able to mark the back sloping angle quite easily.
I hope this makes sense.
Before laying the next brick up I would transfer the dimensions of the lower brick's top side to the bottom of the upper brick and that seemed to work quite well.
Thank you for your kind words.
Chip
Chip
