Mississippi 44"
    • 3884
    #181
    Re: Mississippi 44"
    I forgot to add this expanded pic of the damper control tunnel. The short piece of pipe sandwiched between the washers places the ceramic fiber rope in a little bit of compression. That seems to expand it nearest the outside of the sheath. Not sure if that is important but, I hope it seals off a very small route for the flu gasses and or fire . Damn, I said the F word .
    Packed this whole cavity with 6 to 1 vcrete.
      • 3884
      #182
      Re: Mississippi 44"
      Removed those unsightly novice speed poles and I am now into the ceiling of the A frame.
      The next step-in will be the 20" X 20" OD. 8 rows will clear the roof .
      • brickie in oz
        • 3445
        #183
        Re: Mississippi 44"
        Every bricklayer I know uses them, makes more money that way, so why not...
        • Tscarborough
          • Oct 2009
          • 3341
          #184
          Re: Mississippi 44"
          Yeah, they are not for novices, just not usually used on columns/chimneys.
            • 3884
            #185
            Re: Mississippi 44"
            Originally posted by Tscarborough
            ... just not usually used on columns/chimneys.
            I agree with that. For columns I usually set four vertical strings for the corners and use a level for the individual courses. In a shady dark place, with these old eyes of mine, I find it a little easier to see that bright orange string than that damn near invisible bubble .
            • Tscarborough
              • Oct 2009
              • 3341
              #186
              Re: Mississippi 44"
              Jack lines. What is the difference between the string used for them and that used for horizontal stringlines? (Not for you, Gulf, other readers)
                • 3884
                #187
                Re: Mississippi 44"
                Tscar, you may have underestimated me . It has been a few days and no bites. Back in the day we always cut ours off the same roll of thin nylon twine as we did for the course lines. That was also the same roll which we made the staging for out trot lines, but I digress.
                What is the difference?
                • Tscarborough
                  • Oct 2009
                  • 3341
                  #188
                  Re: Mississippi 44"
                  Twisted for jack lines, braided/bonded for string lines.
                    • 3884
                    #189
                    Re: Mississippi 44"
                    Is that because horizontal lines need more stretch?
                      • 3884
                      #190
                      Re: Mississippi 44"
                      I set some more speed poles to lay the final leg through the ridge. The final inset ended up being 21" X 21" OD. I had figured in my head, thinking 20" X 20" not allowing for the mortar joints. That works out better though, I now have 2 and 1/2 " of 6 to 1 Vcrete between the flue brick and the face brick. That might be important since I went with wood fraiming instead of metal.
                      I custom made some some counter flashing to build into the chimney. The trim is 3/4" X 3/4".
                      One good thing about metal roofs, if you lay it out to where one run is sort of centered with your chimney, you can remove the screws and have fairly easy access to work. You can then slip it right back into place until the next weekend. You see the tarp to the left of the pic, I still trow it over and bungie it down as long as the flashing is not complete.
                      These 2" knotched brick look like the real deal from the face. Allows room for insulation and trims a lot of weight from the final structure. I am still using the original HF blade .
                        • 3884
                        #191
                        Re: Mississippi 44"
                        I transitioned the to an 8" 1/8" SS round just in case I may have misfigured Brickies allowances for nearby structures. I also have a tree line due South of the oven. I am allowing the possibility of adding a double wall section 8" SS vent and cap which I picked up at a local salvage dealer for a good price.
                        I did not shell out for an anchor plate. This 4 and 1/2" piece of SS was scrap and I think that that once it is surounded by Vcrete and brick, it will be anchored just fine.
                        Tomorrow I hope to begin the MQ's crown .
                        • Tscarborough
                          • Oct 2009
                          • 3341
                          #192
                          Re: Mississippi 44"
                          Looks verra nize! Twisted sags more than braided, ie you can pull braided tighter, but you do not need it for vertical stringlines.
                            • 3884
                            #193
                            Re: Mississippi 44"
                            Thanks' T,
                            I figured that you were waiting on someone else to bite or give the right answer. I really wasn't sure. The size houses I grew up building did not need a whole lot of stretch to keep the sag out .
                            • brickie in oz
                              • 3445
                              #194
                              Re: Mississippi 44"
                              I cant find the link so here is the pic again, I assume you mean this very artistic rendition...
                              • Amac
                                • Nov 2011
                                • 358
                                #195
                                Re: Mississippi 44"
                                Good work gulf - now that is a chimney
                                Why did you not use loose vermiculite in the cavity?
                                Amac
                                Link to my WFO build
