Re: Texman Build
Great Build Texman,
I noticed in one of your pictures you are using Alsey Refactories bags. Is this mortar "Sarabond"? I ordered 3 bags from Larkin Refactory in Gorgia, and this is the material they sent. I am debating whether to use this material or use the home brew. I believe it will be good mortar. Did you just add small amount of water, or do you add some sand as well? Also, looks like your brick height is 3 inches, is this correct. I plan to do the same.
thanks
Manny
Great Build Texman,
thanks
Manny
