Re: Wood Fired Beehive in Utah
Thanks Russell! That would be awesome! I think I'm going to try and route a cove kerf in between the arches that would hold the rope. I've used a regular router bit on stone before (I was desperate!!) and it actually worked. Wouldn't exactly use that bit again but for the 40" or so I needed to route I think it'll work..
If you like the color on the tops I can send you some of the colorant I used. I bought 5 lbs of it and after doing the conversions to bags of concrete I don't think I even used 1 lb. If I remember right it was something like 3 lbs to a cubic yard. I used a HF (love that place BTW) scale to measure it out per bag and put it in ziplocs..
Thanks again and if need some $$ let me know!
