K79 Oven Build
  • mrchipster
    • Apr 2010
    • 1502
    #301
    Re: K79 Oven Build
    Fish hook and weight is a great idea.
    Nice top of the arch brickwork. I wish mine looked that good. Another fine example of the benefits of the reaching arch design.
    Chip
    Chip
    • K79
      • Nov 2012
      • 391
      #302
      Re: K79 Oven Build
      Thanks mrchipster. I got ring 6 done today. First time using a babysitter. Worked out great all around !
      Link to my oven build on YouTube:
      http://www.youtube.com/watch?v=Ujb7lqVcSzQ
        • 5264
        #303
        Re: K79 Oven Build
        I see your tapered arch paid off dividends.............worth the brain work out?
        • K79
          • Nov 2012
          • 391
          #304
          Re: K79 Oven Build
          You have no idea...wait... yeah you do ! I love it.
          • K79
            • Nov 2012
            • 391
            #305
            Re: K79 Oven Build
            I have 4 rings left. I'm hoping to be down to my last two by the weekend. Question: My last two rings consist of 13 and 10 bricks (on paper) so is it ok to put in my 13 ring layer and then put my 10 brick layer in right after or should I wait a day and let the mortar set on the previous layer? Same question for my keystone.
            thanks
            • boerwarrior
              • Apr 2013
              • 454
              #306
              Re: K79 Oven Build
              I did my last 3 rows and keystone all on the same day. Been curing a little over a week and no cracking yet - I'm sure that will change once I start firing!
              Neil
              • K79
                • Nov 2012
                • 391
                #307
                Re: K79 Oven Build
                Neil
                Think positive !! Make sure you post a photo of your first fire !
                • K79
                  • Nov 2012
                  • 391
                  #308
                  Re: K79 Oven Build
                  Ok final dimensions for my vent:
                  (Using a 4' x 7" ss double wall chimney)
                  Oven opening: 200 sqin
                  15% of oven opening: 30 sqin
                  7" Diameter Chimney: 38.48 sqin
                  Vent opening unobstructed by inner arch, outer arch, and anchor plate for chimney: 34sqin.
                  How do these numbers look to you guys...?
                  • boerwarrior
                    • Apr 2013
                    • 454
                    #309
                    Re: K79 Oven Build
                    Hi K79,
                    well as you know I am still working from theory....! But I am planning to ensure that my opening is larger in terms of area than my chimney... I have a 6 inch diameter chimney pipe (28 square inches) - and I plan to make the vent opening 5"x 8" (40 square inches) to ensure that nothing is being restricted until the smoke/air hits the chimney vent cap.
                    I would be interested myself in reading other responses from experienced builders/users!
                    Neil
                    • K79
                      • Nov 2012
                      • 391
                      #310
                      Re: K79 Oven Build
                      Hi K79,
                      Neil
                      Your vent landing must be larger than one brick in length right? My opening is 5.5" by 7.5" so I have 41.25sqin but my anchor plate is resting on each so that eats up some of my area. Yours must be the same ...
                      • boerwarrior
                        • Apr 2013
                        • 454
                        #311
                        Re: K79 Oven Build
                        sorry it looks like perhaps I misunderstood your measurements....
                        Not sure what you mean by vent landing? You mean the flat bit that the SS chimney vent plate sits on? If your opening is 41 sq in and you are doing your best to taper into the 7" diameter hole then I think you will be good.
                        Neil
                        • K79
                          • Nov 2012
                          • 391
                          #312
                          Re: K79 Oven Build
                          Neil
                          By vent landing I'm referring to the flat area directly under your chimeny between your inner and outer arch. Yes I'm doing my best but we'll see
                          • boerwarrior
                            • Apr 2013
                            • 454
                            #313
                            Re: K79 Oven Build
                            Ok that's what I thought! Yes, mine is 5" deep so less than a brick length from front to back! Which means I will be able to use full bricks to frame the flat chimney support.
                            Yours sounds fine to me. Why are the experienced people not weighing in? Do they enjoy watching the newbies trade theories?
                            Oh well, next year you and I will be the smart ones!
                            Neil
                            • Tscarborough
                              • Oct 2009
                              • 3341
                              #314
                              Re: K79 Oven Build
                              It all looks good to me except for the thickness of your bottom courses. I predict that you will not achieve burn off there, and also predict that it will make absolutely no difference in the performance of your oven. Looking great!
                              • K79
                                • Nov 2012
                                • 391
                                #315
                                Re: K79 Oven Build
                                Neil
                                I don't know. Either way I'm sure we're going to love our ovens.
