K79 Oven Build
  • K79
    • Nov 2012
    • 391
    #316
    Re: K79 Oven Build
    My "grappling hooks" in action...
    Link to my oven build on YouTube:
    http://www.youtube.com/watch?v=Ujb7lqVcSzQ
    • K79
      • Nov 2012
      • 391
      #317
      Re: K79 Oven Build
      Ok instead of hijacking boerwarrior's thread I'll sort of repost my question here:
      The issue of placing a parging layer around the entire outside of the oven dome has come up. cobblerdave has strongly recommended this step. What do you all think? I've been following the FB plans and this wasn't in there. Does it go on before or after the curing fires, do i need to let the parging layer cure for two weeks before curing fires...
      I'm thinking of using one of the following:
      Premix Conproco Type "S"
      Dragon Type "S"
      Conproco Type "S"
      Structural Skin by Conproco
      or
      NOXCRETE (only one that I can use metal fibers in if you guys think that needs to be done as well)
      Anyone use these?
      • K79
        • Nov 2012
        • 391
        #318
        Re: K79 Oven Build
        I called Conproco and they said that I shouldn't use their product if the temp gets over 500 degrees. So that's out right?? Dragon said no also. The NOXCRETE would work but I'ld have to form around the dome to use it and my slab can't handle the increase in size to be able to add my studs and concrete board for my veneer. ughhhhh..... What about vermicrete would that work....
        Local mason told me that the Conproco should hold up to the secondary heat outside the oven. Maybe the Conproco Rep I spoke with was thinking of direct flame contact....
        • boerwarrior
          • Apr 2013
          • 454
          #319
          Re: K79 Oven Build
          Dragon Type "S"
          Conproco Type "S"
          or
          Anyone use these?
          I don't mind you hijacking my thread! It is a great question!
            • 9216
            #320
            Re: K79 Oven Build
            Originally posted by boerwarrior
            Ok that's what I thought! Yes, mine is 5" deep so less than a brick length from front to back! Which means I will be able to use full bricks to frame the flat chimney support.
            Yours sounds fine to me. Why are the experienced people not weighing in? Do they enjoy watching the newbies trade theories?
            Oh well, next year you and I will be the smart ones!
            Neil
            I think a shallow entry is a great idea, it makes the oven much easier to work, but is not that easy to do with bricks, it is much easier if you cast the whole entry. You do need to make sure that the oven is adequately flued if you make the entry shallow, because the smoke is closer to the external arch.
            • boerwarrior
              • Apr 2013
              • 454
              #321
              Re: K79 Oven Build
              david s,
              sorry I wasn't clear.. (I need to be more careful with my posts!).
              It is my chimney vent (flue) opening that is 5" deep. My entire landing is going to be 12 inches front to back - and actually 15" if I include the decorative outer arch.
              Neil
              • K79
                • Nov 2012
                • 391
                #322
                Re: K79 Oven Build
                Completed my dome !!
                  • 3885
                  #323
                  Re: K79 Oven Build
                  Simply beautiful!
                  Great job .
                  • kbartman
                    • Feb 2013
                    • 572
                    #324
                    Re: K79 Oven Build
                    Congratulation, job well done. Looks great!
                    Respectfully,
                    KB
                    My build
                    • Greenman
                      • Feb 2013
                      • 1123
                      #325
                      Re: K79 Oven Build
                      Excellent! Very impressive. You must be proud of that work.
                      As a sage told me 'good start'. I thought it was a bit flippant but there was as much work again after the dome was done.
                      Dome completion at post 322 must also be a record! The conversations along the way have paid a dividend in the quality of the dome. Good luck with the ongoing build.
                      Cheers .......... Steve
                      Cheers ......... Steve
                      • Ken524
                        • May 2007
                        • 1655
                        #326
                        Re: K79 Oven Build
                        Very nice! Almost ready for pizza!
                        Ken H. - Kentucky
                        42" Pompeii
                          • 5264
                          #327
                          Re: K79 Oven Build
                          Good job K79.....
                          • Les
                            • Sep 2005
                            • 2945
                            #328
                            Re: K79 Oven Build
                            Great job! Feels like you have given birth, doesn't it?
                            • mrchipster
                              • Apr 2010
                              • 1502
                              #329
                              Re: K79 Oven Build
                              Another beautiful oven and some great dome photos, proud. Papa.
                              Chip
                              Chip
                              • K79
                                • Nov 2012
                                • 391
                                #330
                                Re: K79 Oven Build
                                Thanks everyone for the kind words. It does feel great to have the dome complete. I'm excited to get my arch finished and the wet saw out of my garage
                                Next...
                                3 coats 1/4" thick of Comproco Type S mortar mix to parge the outside
                                Build my outer arch
                                Wrap in insulation blanket
                                Then start my fires (2 weeks from now)
                                The saga continues..........
