K79 Oven Build
  • Ken524
    • May 2007
    • 1655
    #466
    Re: K79 Oven Build
    Congratulations! Looks fabulous!
    Ken H. - Kentucky
    42" Pompeii
    • K79
      • Nov 2012
      • 391
      #467
      Re: K79 Oven Build
      Thanks Ken.
      I'm working on my enclosure tonight. 18 gauge metal studs for my frame and 20 gauge for my roof. pics to come.
      Link to my oven build on YouTube:
      http://www.youtube.com/watch?v=Ujb7lqVcSzQ
      • K79
        • Nov 2012
        • 391
        #468
        Re: K79 Oven Build
        Hello All,
        I'm contemplating not putting any loose vermiculite over my 3" of ceramic fiber blanket. Any thoughts? The FB plans say if you have 3" of ceramic fiber blanket that it's not needed, but I was wondering if any other builders had their own take on this.
        Thanks.
        • Laurentius
          • Nov 2010
          • 923
          #469
          Re: K79 Oven Build
          Originally posted by K79
          Hello All,
          Thanks.
          Don't, I didn't.
            • 5264
            #470
            Re: K79 Oven Build
            Since you are in firing mode, take some temp reading on the outside of the CF and see what you are seeing compared to ambient. Then decide. Loose Vermiculate is relatively cheap $10 a 4 cubic foot bag.
            • K79
              • Nov 2012
              • 391
              #471
              Re: K79 Oven Build
              I'm paying $25 for 3 cf That's a good idea. I was hoping to fire it up again once I was done with the oven. 10 days of 8hr+/- fires I needed a break haha.
              • mrchipster
                • Apr 2010
                • 1502
                #472
                Re: K79 Oven Build
                Since i assume you are building a house around your dome, filling it with perlite or vermiculite is cheap easy and I think money well spent for future heat retention. I love the fact that my oven holds heat for several days.
                Just saw your price on vermiculite, Ouch! check your local commercial greenhouse supplier for perlite, sometimes concrete block suppliers have it as loose fill for block.
                Chip
                • deejayoh
                  • Jul 2010
                  • 1893
                  #473
                  Re: K79 Oven Build
                  I found the vermiculite to be ridiculously expensive too, and not worth the "insurance". Outside of my insulation was already at ambient temp, so it seemed like overkill. I have 3-4 inches of FB blanket and no issues with heat retention.
                    • 5264
                    #474
                    Re: K79 Oven Build
                    If you do decide on adding loose fill, check out a concrete block supplier for pricing, it is used to fill CMUs cells for insulation vs a big box store.
                    • stonecutter
                      • Jun 2007
                      • 2003
                      #475
                      Re: K79 Oven Build
                      Keep in mind block fill is almost always finer in particle size.
                      Old World Stone & Garden
                      John Ruskin
                      • K79
                        • Nov 2012
                        • 391
                        #476
                        Re: K79 Oven Build
                        Anyone here know what most people use for gloves when putting stone veneer on their enclosure. I've been doing it bare handed and I now have no fingerprints and I've gone through a box of band aids. Very painful. The issue is you need to be able to work the stone and clean up the excess mortar around the stone. I'm constantly in and out of a bucket of water wetting the stone and sponges to clean them. Rubber gloves offer no sense of feeling when working with the stone and heavy duty suede gloves get soaked in 2 minutes. My hands just can't take it anymore. It hurt just to type this message
                        • stonecutter
                          • Jun 2007
                          • 2003
                          #477
                          Re: K79 Oven Build
                          I don't always wear gloves, but when I do, I use Atlas Dipped gloves.
                          Atlas Fit Glove, Large - Amazon.com
                          Stay healthy, my friend.
                          John Ruskin
                          • stonecutter
                            • Jun 2007
                            • 2003
                            #478
                            Re: K79 Oven Build
                            Also, you should not be pointing with your fingers....get a tuck pointer for that task.
                            This one should be about right for your joint size.
                            MARSHALLTOWN The Premier Line 502D 6 1/2-Inch X 3/16-Inch Tuck Pointer with DuraSoft Handle - Amazon.com
                            John Ruskin
                            • GIANLUCA
                              • 136
                              #479
                              Re: K79 Oven Build
                              what did you end up paying for the veneer per sq foot?
                              • K79
                                • Nov 2012
                                • 391
                                #480
                                Re: K79 Oven Build
                                Thanks stonecutter !!
                                I paid $10.45/sf. Real stone veneer, not precast.
