K79 Oven Build
Re: K79 Oven Build
They may have not been reading your thread. I think Gulf and David have a point. I see no compressive load holding in your vent transition bricks. It looks awesome but what is holding them in place when the mortar bond is compromised?Check out my pictures here:
If at first you don't succeed... Skydiving isn't for you.Comment
Re: K79 Oven Build
There is 3.5" of brick in the front forming a full arch with all tapered brick creating the compressive load. If I got rid of that mortar right now that arch would still hold true. How could that brick slide down? Something would have to give on the front side of the brick.Comment
Re: K79 Oven Build
I think Ken524 did his very similar to yours and as far as I know has reported no problems. I would think that the compression on the one side should hold, provided the arch doesn't move away from the inner arch, it shouldn't be able to drop should it?Comment
Re: K79 Oven Build
Amen brotherComment
Re: K79 Oven Build
Creating the entry using bricks requires some complex brickwork and usually results in an entry way deeper and heavier than you would otherwise want. I don't know why more don't choose to cast it, or at least the top section, it's so much easier. I guess you guys are so into cutting and shaping bricks that you're on a roll when it comes to doing the entry and changing the building method does not come to mind.
Didn't the fourth little pig cast his house after the wolf rattled the brick one to bits?Kindled with zeal and fired with passion.Comment
Re: K79 Oven Build
Casting would be a fun project. Maybe on my next oven.........Comment
Re: K79 Oven Build
uh oh.. .did i overlook expansion joints on my oven floor bricks between my walls. Mine fit a little snug. How much of an issue is this?Comment
Re: K79 Oven Build
K79,
my floor bricks are moving way less than I was led to believe. And I had my oven full of wood yesterday with temps way over 1,000 degrees.
Given that it is too late to do anything about it - I wouldn't worry! You will get some cracks and that is OK!Comment
Re: K79 Oven Build
Well technically it's not to late my floor bricks have been cut so they can be removed I just don't want to
Re: K79 Oven Build
well in that case let's see if you get any responses from more experienced builders - I am still a newbie!Comment
Re: K79 Oven Build
The circumference of the oven will expand much more (relatively speaking)than the floor so it is not a problem.Comment
Re: K79 Oven Build
My sense from reading the forum is that the notion of an expansion joint around the floor started out as a slightly-overkill precaution and has taken on a life of its own. One builder (I've forgotten who) had significant cracking in their dome and blamed it on a chunk of mortar falling in between the floor and the dome walls. Mind you, I seem to recall that the cracking in this case was mostly a cosmetic problem, as is almost always the case with these ovens.
Since then, a number of builders (myself included) have stuck cardboard or some other temporary and flamable buffer to both create an expansion joint (and probably an overly large joint at that) and more importantly to prevent anything else from falling into the gap. If your bricks are snug, you've probably prevented anything from falling in, and as David and Tscar note, you won't have any problems with the bricks themselves.Comment
Re: K79 Oven Build
Here are the approximate numbers from 80 degrees start to 1000 degrees:
42" dome will expand from 131.94678" circumference to 132.673953365", the floor will expand from 42" to 42.23146666. No problem.
My walls are always hotter than the floor, even at the bottom until it evens out after being doored overnight.Comment
