Keystone Size
  • Tscarborough
    • Oct 2009
    • 3341
    #16
    Re: Keystone Size
    What size is your inner arch opening?
    • K79
      • Nov 2012
      • 391
      #17
      Re: Keystone Size
      Not exactly sure yet, I don't know how I'm gong to build it. A complete arch or one like the image below. I'm leaning towards the one one in this image.
      Link to my oven build on YouTube:
      http://www.youtube.com/watch?v=Ujb7lqVcSzQ
      • Tscarborough
        • Oct 2009
        • 3341
        #18
        Re: Keystone Size
        Well, if you built that one, it would be 225.8 SqIn, so you would need a minimum of 33.87 SqIn of draw, and really more would be better unless you plan on a tall stack.
        • K79
          • Nov 2012
          • 391
          #19
          Re: Keystone Size
          I have 235sqin so if I go somewhere between 35 and 40 sqin for my vent opening I should be ok.
          What are your thoughts on the arch itself? I was thinking of a 36" stack... too tall? I'ld love to be able to do it a little smaller.
          • Tscarborough
            • Oct 2009
            • 3341
            #20
            Re: Keystone Size
            Then use an 8" round metal flue, that gives you 50.26 SqIn. 36" is a short stack, so the extra will help.
            • K79
              • Nov 2012
              • 391
              #21
              Re: Keystone Size
              I was trying to figure it out building it out of clay flue liner and brick. I couldn't find anyone local that had any ideas on how to run the 8" ss stack out the peak of the roof. Issues with the weather stripping and such. This and cost has pushed me towards the clay option. would 40 sq in work with a 36" stack?
              • Tscarborough
                • Oct 2009
                • 3341
                #22
                Re: Keystone Size
                I do not understand the difference between piercing the roof with double wall pipe or masonry?
                • K79
                  • Nov 2012
                  • 391
                  #23
                  Re: Keystone Size
                  I don't either... this is all new to me.
                  • kbartman
                    • Feb 2013
                    • 572
                    #24
                    Re: Keystone Size
                    Square/rectangular flues are measured o.d., while round ones are measured i.d., FYI.
                    8x8 is a common size for clay flue liners, with 30.58 SqIn of draw: 6.25 (i.d.)/2 gives a radius of 3.12, 3.1416x(3.12x3.12)=30.58. When calculating draw you draw the largest circle(s) that will fit in the area and use that dimension. The area of the flue should be around 15% of the size of the inner opening, and more is better up to a limit.
                    (the floor size doesn't really matter for draw)
                    Tscarborough,
                    Hope im note butting in I'm new to the furum. (More is better to a limit.) What is that limit? I'm thinking of using 8 x 17 flue on a 40 inch oven.
                    K79 been reading your build looks good.
                    Respectfully,
                    KB
                    My build
                    • K79
                      • Nov 2012
                      • 391
                      #25
                      Re: Keystone Size
                      Originally posted by kbartman
                      Tscarborough,
                      That seems like a lot. It'll be interesting to see what everyone thinks.
                      • Tscarborough
                        • Oct 2009
                        • 3341
                        #26
                        Re: Keystone Size
                        Basically, the draw would be twice an 8x8, the floor size doesn't matter, what is the inner arch opening size?
                        They make the flashing for the double pipe penetration, the masonry chase is done with step flashing. In either case you probably want to offset it so that it penetrates a flat plane not the ridge. In my case I made it a shed roof for more protection in front and I didn't want to offset the flues.
                        • kbartman
                          • Feb 2013
                          • 572
                          #27
                          Re: Keystone Size
                          I limited to 8" on my depth and the 8" X 17" was one of standard flues stocked at the brick yard,the other were to small or to big. I thought it would work. Now I'm unsure
                          The other day Utahbeehiver was worried about highjacking someone's thread to answer one of my questions. Is this consider highjacking? Dont want to affend anyone. I need all the help I can get.
                          Respectfully,
                          KB
                          My build
                          • Tscarborough
                            • Oct 2009
                            • 3341
                            #28
                            Re: Keystone Size
                            Up to the OP on the highjacking, some threads wander all over. That size should be OK, though.
                            • kbartman
                              • Feb 2013
                              • 572
                              #29
                              Re: Keystone Size
                              Thanks,
                              Tscarborough, OP?
                              Respectfully,
                              KB
                              My build
                              • Tscarborough
                                • Oct 2009
                                • 3341
                                #30
                                Re: Keystone Size
                                Original poster, the owner of the thread.
