My 40" Inch pizza oven in Florida
  • stonecutter
    • Jun 2007
    • 2003
    #586
    Re: My 40" Inch pizza oven in Florida
    It looks great, very cohesive and professional looking!
    I don't remember advising you on a drain for the vent....I probably post too much.
    Old World Stone & Garden
    John Ruskin
    • kbartman
      • Feb 2013
      • 572
      #587
      That is something you should address with flashing or something. A sealer like the one I recommended won't keep standing water out for long and using a surface sealer won't help anything but absorption.
      You should get that issue sorted out before you seal anything. I have some ideas but it would be good if you take some perspective pictures...no macro shots....it's better to see the whole area.
      This is the post that challenged me to sort out possible water intrusion into front my oven. With your thoughts, others suggestions and comments I was able to sort it all out.
      Thanks again all.
      Respectfully,
      KB
      My build
      • kbartman
        • Feb 2013
        • 572
        #588
        PS,
        Stonecutter,
        Thanks for the compliment your have been a big help to me and many others.
        Your advice is and should be highly regarded to anyone who receives it. Keep posting
        Respectfully,
        KB
        My build
        • Campmaki
          • Dec 2013
          • 141
          #589
          Kbartman and Stonecutter, I really believe we have started a valid conversation with the vent pan. No only for those building in wetter climates, but in areas where there is freeze/ thaw cycles.Never having a chance to completely dry out insulation.
          • stonecutter
            • Jun 2007
            • 2003
            #590
            Originally posted by kbartman
            PS,
            Stonecutter,
            Thanks for the compliment....
            It's well deserved. You know, good information is only a help if the person receiving it puts it into practice. I think your build is not only a great example of how being flexible will produce a fantastic result, but listening to and applying advice. And, any advice should be looked at objectively, not as the law.
            Campmaki, with your current experience with commercial masonry, you know how important flashing is to masonry components...beyond the standard chimney flashing. This is an area that is often over looked...it shouldn't be.
            As an aside, I always extend my insulation slab under the vent area. Even though I've only done enclosures ( the best for keeping out the weather ) I wouldn't omit it if I was just putting a shell on the dome...stucco,tile or units. Given the 1000extra miles builders go during the building process...extra thick foundations, bomb shelter stands etc,etc....a little insulation under the vent is nothing.
            John Ruskin
            • kbartman
              • Feb 2013
              • 572
              #591
              It's been a while................. slow going but I'm making head way. Here are a couple of pictures of my progress.
              Respectfully,
              KB
              My build
              • NCMan
                • Jan 2014
                • 846
                #592
                Looking good, KB. Love the tile work. Very impressive looking project.
                My Build:
                • oasiscdm
                  • Jan 2012
                  • 1239
                  #593
                  Simply one word summary - Exemplary
                  Cheers Colin
                  Oven 1 Completed
                  Oven 1 and surrounds
                    • 5264
                    #594
                    KB,
                    You come a long way and your build was very interesting to watch. Great job.
                    • kbartman
                      • Feb 2013
                      • 572
                      #595
                      Thanks all, for your compliments and help. I could not have gotten this far without everyone's help and encouragement. Still lots to do.........
                      Respectfully,
                      KB
                      My build
                      • kbartman
                        • Feb 2013
                        • 572
                        #596
                        Finally, cabinet doors completed, time to focus on the oven doors. The norm seems to be a insulated door extending into the oven inner arch and having a lip covering a reveal of some sort. My reveal is a lot larger then most so its may take some thought. I'm thinking that a insulate door in front of my inner arch would retain more heat and better insulate the inner arch. Any thoughts?
                        Herb Garden has began I hope I can keep them alive this time. Any other suggestions?
                        Respectfully,
                        KB
                        My build
                          • 3885
                          #597
                          KB,
                          I have a very wide reveal in my oven also. That helps, very much, in accessing the sides of the oven with tools. The extra wide reveal is at least akin to the flared entries that many do. But, without the intimidation .
                          Do make, or have made, an insualted door. It opens up the world for what these ovens can be capable of
                          • kbartman
                            • Feb 2013
                            • 572
                            #598
                            Originally posted by Gulf
                            KB,
                            I love my extra wide reveal, agree with its utility. I will make a insulated door. I'm looking thru the :"Show us you door thread for ideas" hope to find some good ideas and get past the planning stages. I have been holding temps well with just a piece of Hardee board covered with aluminum foil. Cooked pizza last Saturday evening breakfast and dinner Sunday, Monday and Tuesday with supper tonight at 400F temp. Glad I incorporated the heat breaks as you and many others have. I'm thinking once I insulated the door I may have to leave it open just to get the heat out to cook something other then pizza
                            Respectfully,
                            KB
                            My build
                            • kbartman
                              • Feb 2013
                              • 572
                              #599
                              Haven't posted any thing on my thread for awhile, thought I might give a update. I did make a outer door which will be fitted with some type of adjustable vents to be used when I use the oven as a smoker. I did decide to install the chimney extension to get the smoke up and out of the pool area although I painted it high heat white, to tone down a bit. The insulated oven door still eludes, I will get to it eventually. Been enjoying the oven's use and getting better at those pizzas pies.
                              Any way here is a night picture of my her:
                              Respectfully,
                              KB
                              My build
                              • kbartman
                                • Feb 2013
                                • 572
                                #600
                                Happy Holidays and Merry Christmas to all my Forno Bravo friends.
                                Respectfully,
                                KB
                                My build
