Originally posted by kbartman
View Post
My 40" Inch pizza oven in Florida
Re: My 40" Inch pizza oven in Florida
Originally posted by mrchipster View PostKB,
That sure is looking nice. How far from the real kitchen is the oven?
And remember if you turn out a marginal pie..... you might get a dunk in the pool from the recipients for not being a pizza master.
The kitchen is across the pool in the house. Hopefully I can master the pie soon and avoid the dunk, I'm sure I will with everyone expert advice.
Originally posted by texman View Postjust read through your thread. Nice Build.and well done. Congrats.
Texman
Coming from a master builder like yourself,that means a lot.
I like your outer decorative arch I hope to do something similar. I noticed that there is no over lap of the outer vent arch and you have no smoke stains outside of the oven. I was considering having a over lap to avoid stains. The draw of the chimney must be the key.
Hope to put a fire in her soon.
Originally posted by stonecutter View PostThe fact that you loaded the arch and removed the centering without a hinge failure proves you have enough thickness in your arch without adding a buttress. For your span of 20"....3"-3.5" thickness on your arch is sufficient.
That said, you won't go wrong if...
There is wisdom in caution.
I really appreciated all your advice and wisdom.
Ok Guys,
I poured the insulating/buttressing concrete yesterday. I think I should be able to remove form boards today. How soon can I put a fire in her. I'm getting anxious.2 Photos
Originally posted by kbartman View Post...I'll error on the side of safety.....Last edited by stonecutter; 09-06-2013, 06:46 PM.
Originally posted by brickie in oz View PostRead this page, then the whole site.
If you have to buttress a semi circle arch then surely you would have to buttress a semi circle dome too?
One thing for sure, it won't hurt anything if a buttress is included in the build..good insurance.
Texman
KB,
If you have to buttress a semi circle arch then surely you would have to buttress a semi circle dome too?Originally posted by jbruning View PostThat page and site has a lot of interesting and helpful information.
I buttressed my entry arch somewhat because I figured it needed it but more so because of my rudimentary masonry skills and fear that it could be weak because I didn't know what I was doing.
I agree very good article good info, a little above my pay grade and my rudimentary skills also. I'll error on the side of safety. Hope to pour some insulating concrete around the arch today.2 Photos
Ok Guys,
There seams to be some differing opinions going around........One reason I try to error on the side of caution.
If you have to buttress a semi circle arch then surely you would have to buttress a semi circle dome too?Last edited by brickie in oz; 09-01-2013, 11:29 PM.
Originally posted by oasiscdm View PostLooking good in. Still love your entry wide and very well built. Will look at your detail more when I get to this point. A way off at the moment.
Any questions let me know. Although I think there is a lot more experienced help here on the forum. I'll try to help ya anyway I can.
Hope your boy has a great bday.
Ok Guys,
Originally posted by oasiscdm View PostDidn't think that was necessary for a hemispheric arch.
Brickie?
Originally posted by Tscarborough View PostUnless the material the arch is made of is strong enough in tension you need to. Even a hemispherical arch still has force vectors not in line with the legs.
I'm incorporating a four inch rebar reinforced block buttressing wall on each side of my hemispherical arch. At the base of the arch a 2 1\2" void separation between block buttress wall, this will get larger as the arch curves. I plan to fill this with a vermiculite insulating concrete.
I did not feel comfortable leaving my arch un buttressed.
I think I should be able to sufficiently buttress my arch with the proper ratio mixed insulating concrete. I was thinking 6:1 vermiculite to Portland cement.
What are everones thoughts and suggestions?
The caulk at that location will be black soon enough.
Still slow going here. My temporary enclosure to facilitate firing of oven, adding insulation, building permanent enclosure and stuccoing chimney, has turn out to be a major project in it's self. The rainy season will soon be over, and the need for the temporary enclosure will be less.......Oh well I can take my time............
the end of August is here already.
I manage to finish the chimney penetration, finish my heat breaks and put some masonry fire clay home brew cladding on the dome. I used Koawool caulking to seal my heat breaks. The neutral white turn bright white after drying.......ouch. I wish I would have placed the fiber rope deeper into the recess and hid the caulking joint.....Oh well...........the joint is very firm and I agree with DJ and think it will hold up well..... I would have like to have used the safe stuff Utah used, but it was just too pricey at $43.85 each........Now that I think about it 23, bucks difference is nothing............
5 Photos
Keep a close eye on those lights in your oven. I almost melted the rubber coating on the wire with mine. My oven smelled like burnt rubber for a day or so. As far as the removable tray, I only used it when I wanted to end my fire for the night and close my door to keep the heat in when using the coal. Very easy clean up. I used it as well when I was doing my curing fires with wood and for this, yes I did remove that pan a few times to control my heat. Turned out very useful.
KB,
Very nice to see you incorporate a lot of the items we cut our teeth on. Should be firing soon. I agree with DJ that the Pompelli Plans could use some modernizing.
