Re: My 40" Inch pizza oven in Florida
beautiful.
Been slow going on this end, had a little cleaning up after some sloppy brick work. Completed 7th course, inner arch only 4 more bricks left.4 Photos
Originally posted by brickie in oz View PostIf it the same sort of stuff I use which it loos like just a different brand name, dont splash it in your eyes as its a trip to the hospital................. Are speaking from "horsepistol" experience?
Originally posted by kbartman View PostI'm using Super Demon by Plibrico.
Originally posted by Bec1208 View PostThanks for sharing your experience. Spent some time reworking my jigs. Do you have any sense how much the top width of the bricks was reduced by the tilt angle in the early courses? Bruce
Hope my cut to fit approach helps aka: Geometry for Dummies………Ps the cut to fit approach has its disadvantages, one; saw blade wear, offset by brick savings. The savings lost with bad cuts do to my bad geometry calculations. I wish I had the mind of those Geometry pros that have gone before.
Posted quote from your thread to help keep continuity of conversation:
Originally posted by kbartman View PostBruce,
I think you may be thinking what I was thinking at this point in your build. Looking at the dome sheet calculator I input the needed parameters and ran the calculator. The 4th pic shows the spread sheet and the column labeled tilt I set my jig to 15.2 degrees and cut, and said to my self that right.......I think the sheet is talking about the tilt of brick as seen in the 2nd pic........The 1st pic is my jig which I was calling tilt the adjustment done with the long bolt and wing nut..........3rd Pic I'm calling side angle the taper of brick and adjusted by the wood back stop and wing nut............The bevel of the brick which get's rid of the inverted "V" which become more pronounced as the dome grows in courses is very small 1 to 2 degrees thus far.....I am on my 6th course I think it was about 2.5 degrees. I am adjusting the tilt of my jig to by placing my angle locator on the saw blade to find zero then placing it on the table adjusting the tilt accordingly………… trial and error at this point I not sure if this trial and error method will continue to be productive............I’m open to all others suggestions........I'm probably confused on my terms
as usual but I hope this helps.
I'm using Super Demon by Plibrico. It?s made for tight joint 1/4" max. My first tilted course had some shrinkage issues with the larger joint. Brickie suggested I go back and fill any voids after drying some time, which I will do. I have been able at this point to control shrinkage by using my brick scraps wedges to fill the tilt voids. I thought of adding sand to the mortar mix for the shrinkage issue not sure how that would work........ I need more mortar. I may switch to a different mortar on the upper courses, though I don't like the idea of having different bonding materials. So I?ll probably stay with it. I thought the price was good at $ 38 per bucket, which should put me at about $120 total for high heat mortar.
Originally posted by Bec1208 View PostWhich premix are you using? I am using the harbison walker 413 mix and finding it difficult to work with. Doing better now that I making a thinner mix. What has been your experience? Bruce
4 Photos
Originally posted by kbartman View PostThe Premix mortar I?ve been using is pretty sticking so laying the course has been no problem.
I tried the sticks and they kept getting knocked out of place as I was working - it gets cramped in there towards the end. Plus you need longer sticks every row.
I ended up making some hooks that hung over the brick with a weight hanging on a bit of wire on the outside of the oven. Basically just two half brick sized bits of plywood screwed together at a right angle. Drill a whole through the bottom edge for your wire and hang something weighty from it. They work on any row and don't get in your way.
Gudday
I have seem folk use thin sticks to hold the bricks up, freeing up your IT tool to position the next brick
Regards Dave
Originally posted by K79 View PostHey Kbartman it doesn't appear that you have needed any sort of form yet for laying your rings. What are you plans when you approach the top of your dome?
K79,
My goal is to not use any form, only the IT......... Although the last course was a bit challenging to do the dry fit. The next course will lie on a 30 degree angle, which may make dry fitting impossible. Dry fitting has attributed to my success thus far. The Premix mortar I?ve been using is pretty sticking so laying the course has been no problem. I try to lay and mortar the whole course at one time, making overall alignment easier. The last course I laid was done over two days which caused so alignment issues.
I?m considering a ply wood ring set on brick stacks that allows the IT to be used. I can remove; clean brick face and trim the ring for next course after completing each course?????..Just thinking about it is making my head spin???????. That being said I?m open for suggestions.
Looks great to me. I'm getting stuck trying to set jig for first course with a vertical tilt. About to post about this on my thread. Appreciate any help. Bruce
looking great, KB! You have a very nice transition going there! Looks to me like you have most of the hard stuff behind you
Neil
Finalized 6th course today......???.. I now have more respect to those whom have trodden before??? My hat is off to them??.. It not as easy as it looks
??????.. The upper courses I?m sure will prove even more difficult
Having to work on both side of the wall is giving me a work out. My laziness has cost me a few mistake by not walking all the way around to have a look.3 Photos
