A New Journey
  • #31
    Re: A New Journey
    Fridge and sink?
    Looks like a nice layout!
    Old World Stone & Garden
    John Ruskin
    • #32
      Re: A New Journey
      There will be a fridge in the grill island. I've been trying to figure out how to integrate a sink. I'd have to add on to my grill island or put it on one of the sides of the pizza oven. I ran a main line out there when I ran the sprinklers so I could have a sink... but I'm not sure where I would drain to. I will have to look in to that a little more.
      Loren
      My Build - http://www.fornobravo.com/forum/f8/n...ney-19648.html
      SLOB - Salt Lake Oven Builders - For WFO builders in Utah - Join here http://www.fornobravo.com/forum/grou...-builders.html
      • #33
        Re: A New Journey
        Well guys with my front yard and sprinklers everywhere done, I started on the layout this last weekend. Got everything leveled out, went and picked up 2 truck bed loads of gravel (I have short bed Tacoma so it took 2 loads), Picked up a few 2x6's at various lengths and if everything goes well I should be able to have my foundations poured on Saturday. We are also doing a housewarming party that day so it is perfect timing to show people the project I've been working on and talking about. All I have to do before the pour is re-route the electrical to the main structure and then put a junction box so I can run another conduit back in to the grill island.
        It is exciting progress for me. Next week (after I get paid) I can probably get my block ordered. So far the best price I have found is $1.84 for an 8x8x16 paint grade cinder block from a local place called buehner block. I don't know what the difference is between paint grade and standard. Does anyone know?
        So I've included my sketch up drawings (these include the exact block number I will need) and my concrete pour prep pictures. Tell me your thoughts and Ideas/suggestions as always but so far I think I'm on the right track. (the concrete will of course be rebar reinforced when I pour) My truck is dirty from offroading last week... another fun hobby
        Loren
        • #34
          Re: A New Journey
          Additional Pics. I still need to figure out how to show image in text when using my G+ album... if you guys know... let me know... I think there is a thread on it somewhere.
          Loren
          • #35
            Re: A New Journey
            Paint grade has a consistent surface...but that sounds high for block. If you plan to do anything other than paint use standard CMU. they should only be around 1.20-1.60
            John Ruskin
            • #36
              Re: A New Journey
              Loren,
              Nice start and your sketchup layout looks like it will be quite and entertainment center. FYI, Buehner block is where you can get Perlite when you get to that point. It runs about $9-10 a four cubic foot bag as well as wire ladder reinforcment for concrete counters if you go that way.
              • #37
                Re: A New Journey
                Thanks Russell, I am definitely planning on a concrete countertop. I have a buddy who does concrete and his friend specializes in counters. He did his entire kitchen for about 900 bucks and they were all nicely colored. I think for the main pizza oven section though I'll do the standard concrete counter myself. we'll see though. I need to get my pad poured and then I'll be ready for the block.
                Loren
                • #38
                  Re: A New Journey
                  Buehner block gave me a quote for standard cmu and it was actually more @ $2.03 per block. I'll have to continue shopping around since I would like it to be delivered. Since I need about 250 blocks my Taco won't be able to take nearly that many with 1 or 2 trips max so it is more worth it to get it delivered.
                  Loren
                  • #39
                    Re: A New Journey
                    Ok so as many of you know I initially purchased two blades a cheaper one and an expensive one. With the expensive black one I was only able to cut 11 bricks in half which was far from the expectation. I was cutting very slow at many times just letting gravity do the work. I cut a medium duty fire brick with no problems but the heavy duty ones are more than twice as dense.
                    I contacted the manufacturer MK and after several emails they were going to replace the blade with something they said should be more suitable for cutting my super heavy duty brick.
                    The cheap blade is right at 11 bricks now and is still cutting pretty good. As backup in case all of these blades go out I bought an additional 3 blades for only 26 bucks from someone here locally.
                    When it comes to cutting I should be set.
                    I wanted to let everyone know that it was great to work with MK. They make great blades and have greate customer service. They reviewed pictures of my brick and blade, and found a different blade more suitable for my needs. I'm looking forward to see how the new blade will cut once the cheapy wears out.
                    Loren
                    • #40
                      Re: A New Journey
                      Welcome to the world of super duty Geneva bricks, warned ya, they are 65% alumina and are #@$ on diamond blades. I would try and minimize your cuts as much as possible. Striving for a tight inside joint only. IMHO.
                      • #41
                        Re: A New Journey
                        Yeah. Luckily most of my large cuts are complete. The majority of the cuts I have left will be smaller and less than half of the previous cuts so I think I'll have enough saw power to get through it.
                        Loren
                        • #42
                          Re: A New Journey
                          Well... This weekend I poured my foundations (had to get it in before the bad weather this week). I had a buddy who does concrete for a living come out and give me a hand with making sure everything was level and he had all of the tools. Initially the pour could have cost me over $1000 having to get a concrete truck and a pump to pump the concrete to the back corner of my yard... but instead I rented a little mini concrete mixer and I ended up Using 2 of them which was about 4 yards of concrete. This cost me about $500 less so thats good. I'm realizing since I'm doing everything oversized it gets quite expensive. I had to spend $100 on rebar alone for the Concrete.
                          It was a fun day and it looks great now that it's poured.
                          I'm shopping for my Cinderblock now... we'll see if I can find a good deal or just have to bite the bullet and buy from a local block supplier.
                          Hope you enjoy the pics.
                          Loren
                          • #43
                            Re: A New Journey
                            Wish we had those trucks in ct
                            • #44
                              Re: A New Journey
                              WOW, that is what my Habor Freight 3.5 cubic foot cement mixer wants to be when it grows up. Great start Loren. It may be hard for you to find enough CMUs off of KSL or Craigs list for the size of your out door kitchen.
                              • #45
                                Re: A New Journey
                                Yeah It has been pretty hard. I found someone in Herriman that has about 200 blocks supposedly and they have them listed for $100. They are red blocks but I don't care since I'll be eventually covering them with Rock. If they don't have enough then I'll most likely go through one of the local block companies and have them deliver for me. Which would change the cost from about .50-$1 to almost $2 per block. There is this guy who I drive by every day when going to and from work and he has tons of block sitting out in his yard but he said he doesn't want to sell... Maybe I'll send my wife over... she has more pull than I do.
                                Loren
