Begining 36" oven in the Missouri Ozarks
  • bobmurphy
    • Aug 2011
    • 78
    #31
    Re: Begining 36" oven in the Missouri Ozarks
    I've been a little remiss about posting photos. I am finally cooking in this thing, and having a great time. I've made pizza three times, baked bread once, cooked a chicken, and made a pot roast.
    I decided to make my own oven tools. I have a wooden peel that I have been using in my electric oven for a long time, but I needed some other tools. I had some nice pieces of sheet metal that I had saved from the trash and it turned out to be perfect.
    I ordered a little heavy on the insulation blanket so I decided to use 4 inches. I am going to build an enclosure. I was not planning on pouring loose insulation in my enclosure since I have 4 in of blanket. Should I fasten this insulation in place in any way? If so how?
      • 5260
      #32
      A few tapcons and some wire should do the trick. Since you are going to enclose, now is the time to secure the blankets. Won't take many wires to hold CF in place.
      • deejayoh
        • Jul 2010
        • 1893
        #33
        I used rebar tie wire w/tapcons. Costs only a few bucks for a lifetime supply, and has the right combo of strength/flexibility.
          • 5260
          #34
          Hey DJ,
          We had our first avalanche near Alta this year although we have not had alot of snow yet.
          • bobmurphy
            • Aug 2011
            • 78
            #35
            Wow, that was a question I should not have needed to ask. Thank you for the kind replies.
              • 5260
              #36
              BTW,
              Those are some serious industrial weight tools you have there. Like the giant pooper scooper (ash) scooper.
              • GarnerAC
                • Jul 2013
                • 242
                #37
                Good build all the way around. Nice neat job on the Insul blanket too! As far as the Perlite, cant have too much insulation. It's cheap and you'll never say "I wish I had less Insulation"
                My build documentary page:
                • bobmurphy
                  • Aug 2011
                  • 78
                  #38
                  Russell, thank you for the comment on the tools. It was a rainy weekend so I spent some time in my shop, but still managed to do something related to the oven project. They look a little heavy, but I have used all of them, and I like the feel, and how they work. Best of all they were made from materials from my scrap pile.
                  Garner, I have been thinking the same thing, but at some point there is a diminishing return on insulation. I have 4" of cf I know more wouldn't hurt, but will it help? Hard to say. Since the weather is turning now, my progress will slow I probably wont have to make that decision for a while.
                  What does anyone else think? If you had 4" of cf would you still fill your enclosure with loose fill insulation?
                  • bobmurphy
                    • Aug 2011
                    • 78
                    #39
                    Too much snow, too cold, it's been a long winter, well long for us anyway.
                    I am finally back working on my oven. I decided to frame with wood, I have have the clearances where needed, and feel that the steel studs and cement board are overkill for this application. I have been using the oven all winter and the only place it even got warm is on the outside is the face of the outer entry arch. Even if I had gone with steel I would have used span rated plywood for the roof decking, so if there is going to be wood in there, it might as well be all wood in there. The fact that I have done a little framing, and have the tools to do it also influenced the decision. A nail gun is a great time saver.
                    I am planning on a couple of lights in the soffit above the landing. Does anyone have any thoughts on this, or if you have lights above your landing will you please share what you like or don't like about your lights.
                    • stonecutter
                      • Jun 2007
                      • 2003
                      #40
                      I have framed all my enclosures in wood, no problems with all the insulation and good clearances.
                      I don't have lights in my current oven, but if I did, they would have a dimmer switch.
                      Old World Stone & Garden
                      John Ruskin
                      • jeeppiper
                        • Mar 2011
                        • 321
                        #41
                        I used a simple under-cabinet light kit I bought at Home Depot. I buried them flush in the soffit.
                        Likes: Look great, easy to install, inexpensive.
                        Dislikes: kit has a touch-sensitive 3-position dimmer switch which will not allow lights to come on with an automatic timer. I still have to go out to the oven every night to turn on the lights.
                        • stonecutter
                          • Jun 2007
                          • 2003
                          #42
                          Those lights look sharp...nice clean looking install.
                          John Ruskin
                          • GianniFocaccia
                            • Jun 2009
                            • 1645
                            #43
                            Great-looking oven. Has that homey, inviting look.
                            • bobmurphy
                              • Aug 2011
                              • 78
                              #44
                              Jeeppiper, That is exactly the photo I was wanting to see. Thank you. I like the look and it seems that I will need some lighting on my landing. I like the little white lights that you have strung up too. I am planning on some type of European market/street cafe type of lights strung up.
                              Stonecutter, Yes definitely dimmers. I may want some fairly bright light on the landing when I want to see, but I am going to want a much softer light for sitting and digesting.
                              • Greenman
                                • Feb 2013
                                • 1123
                                #45
                                That is one sharp looking oven. Great work!
                                Cheers ......... Steve
