Thanks.
I have it covered with a concrete curing blanket. It's a burlap and poly blanket. Not perfect, as the blanket doesn't conform perfectly well to the compound curves of the dome shape. But it helps hold the moisture in. when I pull the blanket off to re-wet the dome, it's still a bit damp.
