Mongo's 42" CT Build
    • 9214
    #211
    Even with the gallery well insulated some of its heat can be lost via the uninsulated face and sides that lead to the flue. Reducing the conduction between it and the inner dome with your rope separation should further slow heat transfer. Another method is to use a lightweight gallery which reduces the heat sink effect by lowering its thermal mass.
    • mongota
      • Jun 2011
      • 428
      #212
      I hope everyone is well!
      I put up a cumaru horizontal board fence and intentionally bought way to much cumaru, my plan was to use the excess for future projects. Here's one of them. Time for new doors for the WFO. One for the outer oven opening and two for the wood storage below.
      Cobbled this together yesterday from some of the drops left over after the fence was done. Gave it a coat of Ipe oil and let it sit. For this one, I'll add a sheet metal shield to the back side, the cumaru cleats on the back will provide a gap between the wood and metal. Once all three doors are done I'll fashion door handles. No thought went into this to make it amazing. The thought was to get it done. And I'm happy with it.
      I might consider cutting the radius down an inch or two so there's a bit of space between the wood and the cast arch. I'll wait to get the wood storage doors done before deciding.
      Click image for larger version  Name:	20250219_132001_resized.jpg Views:	32 Size:	972.2 KB ID:	464212
      Click image for larger version  Name:	20250219_131954_resized.jpg Views:	20 Size:	952.7 KB ID:	464213
      Click image for larger version  Name:	20250219_132219_resized.jpg Views:	20 Size:	1.24 MB ID:	464214
      Mongo
      • mongota
        • Jun 2011
        • 428
        #213
        Got the two other replacement doors for the wood access openings done today.
        Doors are about 24" wide and 26" high.
        Dry fit, using a twig to wedge it in place.
        Ipe oiled up and put to bed for the night.
        Mongo
        • mongota
          • Jun 2011
          • 428
          #214
          Door handles. Old doors had metal handles, I did the same on these. Happened to see these handles on a walk through the hardware aisle at a box store when I was picking up drawer slides for another project. I like the size of them as well as the aesthetic. All three doors are easily lifted with one hand, and the doors hang withing 10-15 degrees of vertical. That makes them easy to remove, place on the ground, lift up, and replace in the openings single-handed.
ID:	464388 Click image for larger version
          Mongo
          • JRPizza
            • Jan 2012
            • 1557
            #215
            Nice doors Mongo! I keep wanting to make some for my wood storage area but have not found the time - maybe I can use yours as inspiration!
            My build thread
            • mongota
              • Jun 2011
              • 428
              #216
              JRPizza
              Thanks JR. I had been needing new doors for a few years, this was an easy way to use some of the offcuts from when I built the cumaru fence.
              Mongo
              • JRPizza
                • Jan 2012
                • 1557
                #217
                They certainly came out nice. Part of my procrastination is my patio has a slope that makes water run down towards the oven. If I do make doors out of wood, I have to do something on the bottom to keep the water from damaging them. Not an insurmountable problem - I just have not come up with a solution I'm happy with yet.
                My build thread
                • mongota
                  • Jun 2011
                  • 428
                  #218
                  JRPizza
                  I'll be adding a small piece of 3/4 x3/4 angle iron to the bottom edge of the doors, all that would be seen from the outside would be the 1/8" thickness of the angle, the upturn of the angle would be on the back or interior side of the door. Cumaru is a pretty tough wood, but the steel angle would act as a wear strip and minimize dings to the wood when I'm moving the doors about. It would also isolate the end grain of the boards from the concrete slab.
                  Mongo
                    • 5263
                    #219
                    That wood sure finishes up nice. Great job and welcome back.
                    • SableSprings
                      Moderator
                      • May 2009
                      • 1310
                      #220
                      Wow, those doors are stunning and being able to one hand & stand 'em off is fabulous. Any worries about developing a rust stain on the concrete from the angle iron strip?
                      Roseburg, Oregon
                      • mongota
                        • Jun 2011
                        • 428
                        #221
                        Hey Mike!
                        I'm not certain of the final detail. I have a few ideas, I'll post when done.
                        Mongo
                        Mongo
                        • NewEnglandNewb
                          • Dec 2022
                          • 73
                          #222
                          Mongo,
                          Those doors are looking great!
                          I do have another material question for you. Were you able to buy your under floor insulation locally? I have tried a few local places I thought might carry an appropriate material and have been striking out. The closest place I have found so far is a Boston suburb. I’d rather not go that far if I don’t have to and shipping is real expensive on the places I found online.
                          thanks,
                          Josh
                          • mongota
                            • Jun 2011
                            • 428
                            #223
                            NewEnglandNewb
                            Josh, I had the same difficulty.
                            I ended up finding a place with very attractive prices on the ceramic fiber board and blanket insulation in New Jersey, it was either in Elizabeth or nearby Elizabeth. Can't recall the name of the place and I just did a few searches to jog the memory but came up empty. I have a half box of blanket insulation remaining, I checked that box and there's no business label on the box. I bought online and picked up in person.
                            I had to go to JFK airport so I added a side trip to Elizabeth to make the pickup.
                            Mongo
                            • NewEnglandNewb
                              • Dec 2022
                              • 73
                              #224
                              Thanks for the reply mongota. There is a distribution international in Sharon mass. I’ll be close to that over April break doing some collage visits with my son, so I’ll just plan on adding a side trip like you did.
