36" in DFW Area - Building the Oven!
Picture #1 - The top 5 bricks on each side were cut into two pieces.... one approx 3" long, one approx 6" long. The mortar joint between the small brick and the larger brick makes up any difference in length and for the material removed by the saw kerf. They were dry stacked in place to make sure they would work!!
Picture #2 - arch brick dimensions = 2 3/8" wide side, 1 11/16" narrow side. 10 at 9" long, 10 at 6" long, 9 at 3" long. 2 base bricks complete the vent arch. Vent bricks (6" long ones) are installed with the wide side in, the others are installed with the wide side out.
Picture #3 - The bricks you see in the back were laid with the wide side facing in. This forms an S shaped curve to form the vent opening. The wooden part of the form for the vent was made by attaching the wood that was cut off from making the arch form and attaching them so that the S curve was formed. These "wings" support the back set of bricks and the middle wooden arch and the front wooden arch supports the front arch bricks. More about the arch form in the jigs and forms part of our build.
