36" Pompeii Build, West Lafayette, IN
    • 3884
    #76
    Re: 36" Pompeii Build, West Lafayette, IN
    I agree that both ways will work. But, I would go with option 2. Set all four corners. level the plate line, and custom cut each stud. There won't be but a hand full of studs between each corner on the sides and back. The front will be mostly custom cuts, anyway .
    Edit: Dakzaag brings up another good point. The sooner that you drill the holes for those tapcons, the easier it will be.
    • Cubslover
      • Feb 2015
      • 116
      #77
      Thanks fellas! What size metal studs are recommended for stone veneer? I could grab them now and lay out so I can drill ahead of time. Is 3 5/8" x 18ga too much or too little? Other options are 16ga. and 20ga.
      "Half of the lies the tell about me aren't true!"
      My 36" Pompeii Build
      • texman
        • Nov 2009
        • 724
        #78
        20 ga is probably enough and easier to cut. you can lower your spacing if you think you need more strength Those thicker ga are hard to cut and get the screws to penetrate-just harder to work.
        Texman
        Texman Kitchen
        • dakzaag
          • Jun 2014
          • 235
          #79
          Last time I used metal studs was 15 years ago and I went with the light gauge. Medium should be fine, not a bunch of stress going on here. Maybe someone else who works with the stuff can chime in.
          • Cubslover
            • Feb 2015
            • 116
            #80
            Thanks guys, the wife is starting to like the stucco igloo look now so I may not drill until I know for sure that we will be building the "house".
              • 3884
              #81
              Sounds like you might now be contemplating an Option 3.
              • texman
                • Nov 2009
                • 724
                #82
                swmbo rules still.
                Texman Kitchen
                • Cubslover
                  • Feb 2015
                  • 116
                  #83
                  Ok, we are proceeding on with the "House" gabled or squared, I don't know yet, but this means I'm also moving on with the rectangular pour for my insulating layer.
                  I pulled my top form off today and it is apparent I didn't do a very good job of working the edges and getting air bubbles out. Pretty upsetting, but I know it will be finished over when it's all said and done. Can I trowel some mortar over the edges to clean them up a bit and fill the pockets?
                  Dave, Lafayette Masonry hooked me up with two big bags of perlite. It's supposed to get below freezing tonight so I will pour tomorrow.
                  As far as the insulation layer, will 3 1/2" suffice or should I frame up a bit to 5"?
                  • dakzaag
                    • Jun 2014
                    • 235
                    #84
                    You might need more perilite before its done. Never too much insulation, but how is your floor height coming out?
                    You can fill the honeycomb with portland/water slurry. If the holes are big, add some sand. Since it gets covered up, really no big deal.
                    • Cubslover
                      • Feb 2015
                      • 116
                      #85
                      I have the two bags from Amazon that turned out to be a bad deal. I'll open them if needed.
                      Height is at 36" now. 3.5" insulation puts it at 39.5+2.5" for the brick=42 as the cooking floor height.
                      • dakzaag
                        • Jun 2014
                        • 235
                        #86
                        What is your elbow height?
                        • Cubslover
                          • Feb 2015
                          • 116
                          #87
                          My elbows are at 44"
                          • dakzaag
                            • Jun 2014
                            • 235
                            #88
                            It is official, and I have suspected this for some time...
                            You're a knuckle dragging neanderthal.
                            You should be fine at that height.
                            • Cubslover
                              • Feb 2015
                              • 116
                              #89
                              Haha. Thanks (?).
                              • Cubslover
                                • Feb 2015
                                • 116
                                #90
                                Well, the perlcrete is easy to mix and easy to work with, BUT...
                                The stuff I got from the masonry place was very fine, it was a breeze to work with. I just didn't have enough. I had to use the crap I bought from Amazon for a terrible deal (which was also extremely coarse) AND everything the local Menards had. By the time the wife got back with more, the front had begun setting up and I had a very hard time feathering them in. The screed board was of no help after a short period of time with this thicker mix. I had to float and level by hand.
                                I just put a 48" level on it 4 places each way and it's level, remarkably.
                                Next time will be CF board for sure.
