Re: Bevel cuts necessary or not
FOR SURE AND FOR CERTAIN read the advice offered on this forum and you won't go wrong. James has offered a tremendous place to convince everyone that they also can do this, including me.
To answer your questions all at once. I've done the bevel and angle cuts on the sides of the bricks to reduce the amount of mortar and also stay in the manufactures 3/8" limit. Another reason I felt good about, this should make each ring lock itself together for support. I use the word taper to describe when I cut the bottom of the brick at an angle - I've done this so I haven't had to raise the back of the brick up to much when I'm trying to get to a 20" ceiling height. Look at Acoma's thread and he has a tremendous build going on. He has used a larger gap initially and did question it during row 6. When he started to remove that row he found that the mortar had really set and decided to go on. I'm not that confident in the Heat Stop 50 I've been using so I'm thinking that RefMix may be a better mortar, though I haven't used it. If shipping wasn't such a factor I would have order it versus buying locally.
If you are getting a wet saw (10") you will find out that cutting these bricks at angles aren't scary at all. It's not like a wood saw at all, more like a grinder. Still be very careful - it is a motorized tool. Cutting the bevels through row 11 wasn't difficult at all, the last two rows being smaller bricks were interesting.
Be confident that you will be able to do all of this. So far the hardest physical part was pouring the hearth. The rest has been extreme enjoyment
Good Luck
Good Luck
