Re: It's time to go Vertical
The PLAN(???) is to have the top of each row aligned to the centerpoint of the floor. I take a long stick from the centerpoint and lay it on the next course to see how high the back needs to be raised.
I started this with the soldier by cutting them at a diagonal 4" in front and 5" in back and the stick laid on it flush. So with a 42" dome the top of the brick was 21.5" from the center and I'll need to get it to 20" by the end.
On the next two rows I had to raise the back up about 1/2". I ended just over 21" from the center at the end of the third. When I tried the same approach with full bricks for the fourth row, I felt the gap in the back was way to much and I wasn't getting closer to the center.
I decided to taper the bottom of this row roughly 1/2" in front to full thickness in back. Then lifted the back up 1/2". This helped close the gap and resulted in less mortar required.
The next row I'm thinking that I may be able to go with full bricks again. We will see today.
