G'day All and Happy New Year,
Thanks Mark, and yes I agree with you on that one.
I've mostly sorted my entry and vent arch design. After trolling the forum for a few hours I do have a couple of questions where I'm a little unsure.
In photo no 1 I've laid out what will be the entry bricks, one and a half bricks long starting at the bottom. Towards the top I'll open out for the vent (the yellow arrow indicates) Its a 42 inch oven and I'm going for an 8 inch flue (about 49 sq inch) and the vent will be around 80 sq inch initially reducing from rectangle to round and about 50 sq inch. Once I'm creating the opening I won't have a very thick brick at the front of the vent, indicated by the green arrow, around 2 and 3/4 inch deep ( fore/aft length). So it will be like photo no 2 and the blue arrow. Is there a depth of that part of the vent arch ( green and blue arrows) that anyone believes would be too narrow?
My second question relates to laying a decorative fascia brick on the front of the vent arch. I may not be able to use a full brick and I'm concerned if I simply mortar a fascia on the front (possibly half brick thickness) It would separate from the vent arch eventually cracking the mortar and becoming loose. Have you laid, or seen a fascia laid on the front of the arch? How did it go and how did you do it??
Thanks in advance for any info regarding these questions, the terrific assistance often flows and is greatly appreciated.
Regards
Regards
