G'day All,
Exciting times, I've run a series of curing fires over the last 7 nights, starting very small with a little charcoal and gradually getting bigger. Last night and this evening I thought might as well cook pizza as the fires are getting hot. I've been using a heat gun and whilst I have increased the temps I think another good indication is the size of the fire and amount of flame. I thought I had a fairly hot oven tonight but the pizza's were taking 5-10 mins to cook so I think that isn't all that hot. Mistakes and tips;
1. I've made some plywood boards, I make the pizza on the board and slide off onto oven floor, works a treat. I did read a tip suggesting that just before actually topping the pizza turn the base over and the drier dough that was on top allows easier sliding off for the pizza, this definitely works.
2. I cooked tonight just after moving the fire to the side from the centre. Not a good idea, the floor of the oven was way too hot where the fire had been.
3. And the pizza, terrific, awesome.
I do have some cracking around the dome, as seen in the photo's. The cracks appear to open up when the oven is hot, not surprising. I cannot detect an increase in heat at the crack compared to either side when using the heat gun indicating air is not getting through from within the dome. Questions
1. Will the dome cracking open and close during each heat cycle over the life of the oven?
2. Any thoughts/recommendations as to whether the cracks should be repaired at all and if so whats the best way? There is quite a few, some possibly slightly wider, I'll grind out the mortar if recommended but certainly not unless it's beneficial? I do expect the cracks would be considered minor.
Many thanks and kind regards
