I wish I could offer you advice on p-crete, but as you know, I chose the easy way out...four inches of blanket insulation!
Curing fires are best in my opinion after the dome is insulated. The insulation can mellow out the temperature as the dome heats and cools. Longer curing fires will ensure that any latent moisture is not just driven out of the brick some, but through the insulation and into the atmosphere as well.
When I don't use my dome for a while, my first cooking fire is typically a low temp long fire, then I add fuel to get to cooking temps. The low and slow fire helps drive out any moisture before getting it to flatbread type temperatures.
If my dome has absorbed moisture? It might not be through the shell, from the outside-in. It can be through the interior cooking space. Humid atmospheric air in the dome can result in some of that moisture being absorbed by the dome structure. But if my dome has absorbed moisture, when I fire it, the exterior stone veneer can feel warm. Once all the moisture has been driven out, the exterior stone veneer is essentially the same as the outside air temperature, even with a 900 degree brick temperature inside.
And to answer directly, yes, curing fires can be spread out.
In time, I'd LOVE to have a few grape vines to provide a summer arbor. However during the winter they will be of little use, so if there's any design out there that allows me to put the "roof" up after labor day and remove at memorial day, I feel that could be a win-win. (Thinking of perhaps a strong canvas material that I can grommet down maybe?)
. A tarp or canvas would certainly work & give you a much extended time outside enjoying your very successful & great looking WFO entertainment area.
