t could be that your circular floor is off a little bit, that is not perfectly circular. I definitely had some issues where it wasn't perfect on the 3rd or so courses, where there was a tiny lip, and I think this was because my circular floor wasn't perfect. It shouldn't be a huge deal in my opinion. In my attached pic on the right side your can see some of the overhang.
I'm assuming your IT was measured appropriately, but I'll note that the center of the wood coming out of the pivot point should line up with the center of a brick. I drew a picture to explain. X is half the height of a brick. So half of the thickness of the green stick plus the whole thickness of the purple should be equal to half the height of a brick.
... Thank you both @ plastered and
. As I am coming up and laying course 4 I had already thought what you just mentioned
, he leaves in about 3 weeks for Daytona (not too far)
