Les' Build
  • mfiore
    • Oct 2007
    • 919
    #76
    Re: Les' Build
    Yep, I must be lucky. I can watch over and over again
    Mike - Saginaw, MI
    Picasa Web Album
    My oven build thread
    • Les
      • Sep 2005
      • 2945
      #77
      Re: Les' Build
      I replaced the link - seems to be working
      Les...
      • CajunKnight
        • May 2008
        • 263
        #78
        Re: Les' Build
        Still couldnt view it so I played with the link and came up with this one. Works for me so hope it works for yall.
        Looks awesome!! at least you got the video before camera melted LOL
        like chicken...
        My 44" oven in progress...
        __________________________
        • Les
          • Sep 2005
          • 2945
          #79
          Re: Les' Build
          Thanks! I replace my link with yours. Youtube has issues - people have been able to view it, then it breaks. Pretty strange.
          Les...
          • Les
            • Sep 2005
            • 2945
            #80
            Re: Les' Build
            Another Youtube attempt. This was on Saturday night. I brought it back up to high temps to see if the cracks would grow - they remained pretty much the same. I spent yesterday starting the insulation process. I am going to add 12 more inches to the height of the flue incorporating a taper ( got that idea from David) If it draws this well like it is - it can only get better.
            YouTube - The second fire
            Les...
            • SpringJim
              • Apr 2008
              • 562
              #81
              Re: Les' Build
              Nice new Avatar....
              • Les
                • Sep 2005
                • 2945
                #82
                Re: Les' Build
                Thanks Jim - it's all about the fire.
                Is there anything easy about this project (except making fire, that was cool). I thought I could simply cover the lath with foil to prevent the vermiculite from escaping - not. The wind blew it all over the yard. Plan B: cover this first course with mortar and pour it in - then go to the next level. Working with this lath is like playing with a box of razor blades.
                Les...
                • dvonk
                  • Mar 2008
                  • 101
                  #83
                  Re: Les' Build
                  Why do you need vermiculite over the blanket?
                  • Les
                    • Sep 2005
                    • 2945
                    #84
                    Re: Les' Build
                    Overkill - more is better. If I can come out 48 hours after a fire, and cook something, that would be awesome (maybe just heat up a can of beans ) My weak point is the door - I was planning on 4 inches but the math doesn't allow it unless I get really creative. Anyway, it was in my plans - I feel compelled to follow it.
                    Les...
                    • dvonk
                      • Mar 2008
                      • 101
                      #85
                      Re: Les' Build
                      I've meant that if your need extra insulation just go for the second layer of the blanket - it's much more efficient and easier to deal with compared loose insulation.
                      I've run my oven twice, the second time I've use a door to seal the heat in - and it was pretty hot two days later. One 4" layer of blanket was just bit warm. I'm going to cover it with a second one and go for stucco.
                      • Les
                        • Sep 2005
                        • 2945
                        #86
                        Re: Les' Build
                        I used 2 rolls of 1 inch blanket. In some spots I am 3, maybe 4 inches thick. I didn't feel comfortable laying the stucco onto the blanket - seems to be a weak spot for cracks. That's why I built the frame out of steel, just my approach.
                        Les...
                        • dvonk
                          • Mar 2008
                          • 101
                          #87
                          Re: Les' Build
                          The idea of the frame is clear, sure
                          ps. my blanket is 2 ply, one layer is about 4"
                          • egalecki
                            • Mar 2008
                            • 1049
                            #88
                            Re: Les' Build
                            How did you get such nice bends on the rebar? Mine always look like a drunk did them.
                            The metal lath can be extremely sharp indeed. Be very careful with your knuckles when you are applying your scratch coat. Several years ago I did a faux stone fireplace for a house we built, and my poor knuckles just didn't have skin for days. That was with gloves. Went thru several pairs- unlike the usual, where I wear out the palm side, I tore off the backs!
                            Your whole project is so well done, you should feel a tremendous satisfaction in it! Even if you're just heating up a can of beans... (which will need to be vented, btw, unless you wanna clean up bean mess...)
                            Elizabeth
                            • Les
                              • Sep 2005
                              • 2945
                              #89
                              Re: Les' Build
                              Elisabeth - I have a picture of the jig I made in the photo gallery. Took a little bit of muscle to form it but not too bad. If I could have bought the 1/4 in instead of 3/8, it would have been a lot easier.
                              Dvonk - I didn't enjoy working with the 1 inch product, don't know how you did 4. That is some serious insulation.
                              Les...
                              • Les
                                • Sep 2005
                                • 2945
                                #90
                                Re: Les' Build
                                Do not do this!
                                I failed miserably. I thought if I made the mortar thick, I could skim it and then pour in some more insulation - WRONG.
                                The lath flexes and the mortar will drop into the cavity. I want to try and use a vermiculite/portland mix to add more insulation (I don't believe I need more but it was in the plans). For those that have been here, whats the best way to mix it. Bucket/wheel barrow? I believe I read that it is a 5/1 mix.
                                Thanks.
                                Les...
