Justin Pompeii
  • Justin
    • Nov 2008
    • 55
    Justin Pompeii
    I have just started a Pompeii oven build. So far i have dug and boxed up a place for a 2m x 3m x 14cm slab.
    Justin
    My 40" Oven progress http://www.fornobravo.com/forum/f8/j...peii-5495.html
  • Justin
    • Nov 2008
    • 55
    Re: Justin Pompeii
    Slab was poured yesterday. Now I,m sore all over (not cut out for manual labour)
    Justin
    • christo
      • Feb 2006
      • 913
      Re: Justin Pompeii
      Slab looks good! Not cut out for manual labor? Looks like you are! One more slab to pour and it's all downhill from there!
      Christo
      My oven progress -
      sigpic
      • Justin
        • Nov 2008
        • 55
        Re: Justin Pompeii
        Got concrete (masonary) blocks delivered today. Dry stacked two rows and its looks pretty good, looks huge though! I used a grinder to remove the 'dags' from concrete moulding process that make them not sit flat on one another. This made them sit alot flatter with less wobble and hopefully less concrete will spill out of gaps.
        Ill post a photo of the block stand tomorrow when theres more light.
        Here is the progress so far. ( i have actually changed it slightly since photo to leave an opening to access rear storage area.
        Justin
        • Justin
          • Nov 2008
          • 55
          Re: Justin Pompeii
          Ok, i finished stacking blocks today and cut up all the rebar. i will pour the concret in the cores tomorrow. Did i mention im doing all this after work each day..soo very tired. haha.
          Justin
          • mannextdoor
            • Mar 2008
            • 172
            Re: Justin Pompeii
            Welcome Mate
            Take your time, you have all summer.
            _______________________________________
            • staestc
              • Oct 2008
              • 256
              Re: Justin Pompeii
              It is looking really good Justin, and I think you will really like the additional access to the storage space as well
              Travis
              TravisNTexas
              • Justin
                • Nov 2008
                • 55
                Re: Justin Pompeii
                Thanks Mannextdoor and Travis. Encoragement makes the pain dissapear, haha.
                Justin
                • james
                  Brick Oven Merchant
                  • Mar 2005
                  • 4648
                  Re: Justin Pompeii
                  Great pizza; better cardio-vascular. :-)
                  • Bandrasco
                    • Oct 2008
                    • 208
                    Re: Justin Pompeii
                    Looks good Justin!
                    I hear ya on the "after work" build process. It takes a lot of motivation to stay at it after a very long day. Not to mention that it's dark now by the time I get home.....Don't get me started on the daylight savings time of the year.
                    Good luck and keep up the hard work!
                    Bill
                    Bill,
                    Check out my build http://www.fornobravo.com/forum/f8/b...egin-5443.html
                    • Justin
                      • Nov 2008
                      • 55
                      Re: Justin Pompeii
                      Ok i poured the concrete cores last night after work, took about 3 hours with 3 people working, not too bad
                      Justin
                      • Justin
                        • Nov 2008
                        • 55
                        Re: Justin Pompeii
                        Today i boxed up for the top slab and tied off the rebar. I'm going to pick up a couple of extra lengths of rebar because i think its a bit light on. Also i threw in some spare mesh just to get rid of it.
                        Justin
                        • Bandrasco
                          • Oct 2008
                          • 208
                          Re: Justin Pompeii
                          Looks great Justin! Keep at it; it goes faster than you think.
                          Be sure to post more pics soon.
                          Bill
                          Bill,
                          • asudavew
                            • Jul 2007
                            • 1880
                            Re: Justin Pompeii
                            It's looking good Justin.
                            I love how you built your stand.
                            I wish I would have done mine that way.
                            Are you planning on hand mixing the hearth concrete.
                            Or are you ordering a truck?
                            Lots of work either way.
                            Keep up the good work.
                            Dave
                            My thread:
                            My costs:
                            My pics:
                            • Dino_Pizza
                              • Feb 2008
                              • 1036
                              Re: Justin Pompeii
                              Hi Justin,
                              The base is looking great! What size oven diameter are you planning on building (my "inch" size brain will try to do the conversion)? Also, I saw your slab dimensions, what is your actual concrete block dimension? I'm having trouble starting my slab because I just can't commit to an oven base length.
                              Also is that some sort of "cement-board" you have on top? I gather you will pour your oven floor on it and leave it there. I've been wondering how much to overlap it over the blocks and you have the clearest picture I've seen on this site.
                              Thanks for sharing the great pics,
                              -Dino
                              My Oven Costs Spreadsheet
                              My Oven Thread
