Justin Pompeii
  • amber
    • Jul 2008
    • 161
    #46
    Re: Justin Pompeii
    Looking good!
    • Justin
      • Nov 2008
      • 55
      #47
      Re: Justin Pompeii
      Did a couple more courses today, started using 1/4 bricks as well. Im a bit worried about this thing staying together now as the bricks are almost vertical.
      Justin
      My 40" Oven progress http://www.fornobravo.com/forum/f8/j...peii-5495.html
      • amber
        • Jul 2008
        • 161
        #48
        Re: Justin Pompeii
        Don't worry, the rest of us have been there, too. Just keep the forms in until everything is dry. Looking good!
        • christo
          • Feb 2006
          • 913
          #49
          Re: Justin Pompeii
          Great advice.
          My arch collapse was likely a result of me removing the forms way too early.
          The oven looks great - you are really close now.
          Any special plans for the keystone?
          Christo
          My oven progress -
          sigpic
          • amber
            • Jul 2008
            • 161
            #50
            Re: Justin Pompeii
            Belive me, Christo, I wanted to take them out about 10 minutes after the Keystone was in place. Dad (who at 62 is somewhat less excitable than I) made us wait a whole day. It was agony. Now I'm glad he did, but at that point I had to go home to keep from touching it.
            • Gryso
              • Nov 2008
              • 8
              #51
              Re: Justin Pompeii
              Originally posted by Justin
              Ok, i finished stacking blocks today and cut up all the rebar. i will pour the concret in the cores tomorrow. Did i mention im doing all this after work each day..soo very tired. haha.
              Ma non ci mettete voi la malta tra un blocco e l'altro?
              Strano metodo....
              Ciao
              • Justin
                • Nov 2008
                • 55
                #52
                Re: Justin Pompeii
                Sorry i havnt posted any updates for a while. So i will summarise what ive been up to for the last couple of weeks
                I finished the dome and covered the main dome part with 2 layers of insulating blanket, the inner one was about 1 inch (25mm) thick and the outer is about 1/2 inch (12mm) thick with a thick aluminum coating. I layered these on the dome and sealed the joins with aluminum tape, this way the insulating concrete liquid will not seep into the blanket
                I then boxed up around the base of the dome ready for insulating concrete, for this i used a product called Shiralite.
                Justin
                • Justin
                  • Nov 2008
                  • 55
                  #53
                  Re: Justin Pompeii
                  I have now finished the insulation then attached inner and outer chimney flu and front veneer bricks. So now i need to render the dome with coloured concrete render and float the top slab up the level of top of floor bricks. I lit the first fire yesterday and nothing cracked or exploded, even at 100-150Deg C for about 1 hour.
                  Justin
                  • Justin
                    • Nov 2008
                    • 55
                    #54
                    Re: Justin Pompeii
                    And a couple more photos..
                    Justin
                    • amber
                      • Jul 2008
                      • 161
                      #55
                      Re: Justin Pompeii
                      Justin - Looks great! You've made a lot of progress.
                      • christo
                        • Feb 2006
                        • 913
                        #56
                        Re: Justin Pompeii
                        Wow- Great progress!!!
                        Thanks for the pics
                        Christo
                        My oven progress -
                        sigpic
                        • egalecki
                          • Mar 2008
                          • 1049
                          #57
                          Re: Justin Pompeii
                          Very nice, Justin. It feels great to light that fire, doesn't it! Even better when the dome stays up when you do!
                          Elizabeth
                          • Modthyrth
                            • Mar 2008
                            • 359
                            #58
                            Re: Justin Pompeii
                            Gorgeous work! I really like the form you made for the insulating concrete layer. I only used blanket, but I've read so many times about that lower part being the most difficult. Nice solution.
                            Nikki
                            • Justin
                              • Nov 2008
                              • 55
                              #59
                              Re: Justin Pompeii
                              Ive been offline for quite a while, but i thought i would add a couple more photos for the sake of completeness, i made the door for wood storage area last weekend, the wood was given to me by a relative for burning in the oven but i thought it had character, lol.
                              Since completion i have cooked around 100 pizzas and a few roasts and bread etc, i absolutely love it!
                              Justin
                              • gjbingham
                                • Sep 2007
                                • 2021
                                #60
                                Re: Justin Pompeii
                                Nice build Justin. The oven turned out really well. Thanks for the final pics. They make for a nice ending to the story.
                                G.
                                GJBingham
