Justin Pompeii
  • amber
    • Jul 2008
    • 161
    #16
    Re: Justin Pompeii
    Justin, it looks good, quick progress. As soon as you start the dome and then especially after the 4th or so course, you can really see the light at the end of the tunnel and it goes fast.
    • amber
      • Jul 2008
      • 161
      #17
      Re: Justin Pompeii
      I get to mix concrete now! I wish I hadn't been allowed to do that earlier!
      • Justin
        • Nov 2008
        • 55
        #18
        Re: Justin Pompeii
        Originally posted by Bandrasco
        Looks great Justin! Keep at it; it goes faster than you think.
        Be sure to post more pics soon.
        Bill
        Thanks Bill, will do!
        Originally posted by asudavew
        It's looking good Justin.
        I love how you built your stand.
        I wish I would have done mine that way.
        Are you planning on hand mixing the hearth concrete.
        Or are you ordering a truck?
        Lots of work either way.
        Keep up the good work.
        Dave
        I am mixing concrete myself, but i have a cement mixer so its not too bad with a few people helping out. The hearth or top slab is much less volume than the foundation slab which i also mixed up myself so it should be ok. only problem is it is so high, i might have to bucket it in rather than just use a wheelbarrow.
        Originally posted by Dino_Pizza
        Hi Justin,
        The base is looking great! What size oven diameter are you planning on building (my "inch" size brain will try to do the conversion)? Also, I saw your slab dimensions, what is your actual concrete block dimension? I'm having trouble starting my slab because I just can't commit to an oven base length.
        Also is that some sort of "cement-board" you have on top? I gather you will pour your oven floor on it and leave it there. I've been wondering how much to overlap it over the blocks and you have the clearest picture I've seen on this site.
        Thanks for sharing the great pics,
        -Dino
        Dino my design is for a 1m internal diameter oven, or approx 40". For this design the foundation slab really only needs to be around 2m x 2m, 78" x 78" but i made mine 2m x 3m so that i have a place to stand at the front while cooking pizza
        Re the cement board, yes it is exactly that, similar to that used in bathrooms and wet areas etc, it actually has a name, ill try and find out for you. I plan to leave it in there once its poured as i've been told it will bond to concrete and never rot etc. the overlap i used is about 100mm or about 4" overlap on top of concrete block. This should be strong enough since i have supported the cement sheet with timber.
        I hope so, i cant wait to start the dome!
        Haha, its fun!, just be sure to wear gloves as cement is really bad for your skin.
        Justin
        My 40" Oven progress http://www.fornobravo.com/forum/f8/j...peii-5495.html
        • Justin
          • Nov 2008
          • 55
          #19
          Re: Justin Pompeii
          Dino, here is a diagram with some dimensions of my slab and block stand, hope it helps.
          Justin
          • Dino_Pizza
            • Feb 2008
            • 1036
            #20
            Re: Justin Pompeii
            Thanks Justin for the measurements.
            My oven will be 42" wide and I was thinking I might take the 78 inch length (5 of our U.S. concrete blocks in length) and possibly reduce it to 4 1/2 blocks but the 2M or 78" looks like the right thing to have with a landing and such.
            Looking forward to pics of your progress.
            Good luck, Dino
            My Oven Costs Spreadsheet
            My Oven Thread
            • Justin
              • Nov 2008
              • 55
              #21
              Re: Justin Pompeii
              I have a few questions, hopefully someone here can help me with.
              Firstly i am planning on using a 50mm (2") slab of insulating concrete with 2 layers of 12mm (1/2") insulating board. Ive been told the insulating board is far superior to insulation concrete and i can probably just use it by itself, however i thought i would compromise and just add a thin 50mm (2") layer of insulating concrete, what do you guys think about this?
              Next, i was originally planning to use 50mm (2") refractory bricks for the oven floor, but then changed my mind to use the 75mm (3") thickness bricks, has anyone got experience with this? is 75mm too thick?
              Lastly, has anyone added a thermal break between the vent arch and the oven dome? im wondering this because we seem to go to so much trouble to insulate the dome and yet the heat can travel from the dome out through the front archway of the oven.
              Sorry for 3 questions, and thanks to anyone who can help me!
              Justin
              • exipnos
                • Aug 2008
                • 43
                #22
                Re: Justin Pompeii
                As far as floor thickness goes, I also went with 70mm brick. Having asked the same question myself the answer is that its not to much thermal mass since after all its less then what your oven walls of approx 4".
                For floor insulation I installed 10cm AAC block. Its a light weight cellular concrete that have similar properties to the vermiculite insulation concrete. If your supporting slab is already completely level and smooth the installation is very simple since its flat squares approximately 62 by 50 cm big. There are some threads here on FB that discuss this material and there are a few builders that have used it with good result. Check it out. If you where to combine your two materials (insulation board and insulation concrete) I would think it will be easier and better to combine insulation board with the AAC instead.
                Just my take on this but by no means am I an expert so take it with a grain of salt
                • Justin
                  • Nov 2008
                  • 55
                  #23
                  Re: Justin Pompeii
                  Thanks Exipnos, you have given me the reassurance that i need for the size of the firebrick floor, i just have minor freak outs some times and feel im designing this thing the wrong way. As for the insulation board, i have already acquired it, its called ISOMAG 70 Structural Insulation. And instead of using vermiculite i have something called Shiralite 120LW.
                  I guess if the normal thickness of insulation is about 100mm (as is yours), and im using 50mm + (2 x 12.5mm) = 75mm, it should be fine. Thats my theory anyway
                  Justin
                  • exipnos
                    • Aug 2008
                    • 43
                    #24
                    Re: Justin Pompeii
                    Hi Justin,
                    Just a recommendation. I'm not sure if you have decided on your dome assembly method but if you have not then I definitely recommend that you go ahead and taper your bricks. I have not and I regret it.
                    Cheers,
                    Kosta
                    • amber
                      • Jul 2008
                      • 161
                      #25
                      Re: Justin Pompeii
                      justin,
                      I've heard about people leaving a break between teh arch and dome, but for expansion/contraction reasons. I have no idea if this is a good move or not. Maybe someone who has done it/thought about it can weigh in?
                      • Frances
                        • Aug 2007
                        • 2186
                        #26
                        Re: Justin Pompeii
                        Don't worry, that's all part of the construction process. You'd probably be doing something wrong if you didn't feel like that...
                        When I was building my dome there were a lot of discussions about having a thermal break between the dome and the archway. I can't remember if anyone actually went that way in the end - the consensus seemed to be that it would be more trouble than it was worth. The heat has to go out somewhere eventually. I believe its also a structural thing, if you have an added break just there, the archway may not tie in with the dome so well.
                        Somebody even had these really neat plans for an inivisible thermal break inside the dome floor just under the doorway. Does anyone remember who that was?
                        • Justin
                          • Nov 2008
                          • 55
                          #27
                          Re: Justin Pompeii
                          Originally posted by exipnos
                          Hi Justin,
                          Cheers,
                          Kosta
                          I was originally planning on not tapering my bricks but i am now thinking otherwise. ill probably end up cutting them as im a bit of a perfectionist.
                          justin,
                          I hope so I guess its not that bg of a deal then since noone seems to do this and thier ovens all work fine..
                          Yeah probably just better to keep it simple. thanks for the advice everyone!
                          Justin
                          • Justin
                            • Nov 2008
                            • 55
                            #28
                            Re: Justin Pompeii
                            Ok, so i made a very elaborate formwork for the insulating slab layer, only problem was that i made the mix too watery and now it taking forever to dry (yes i am impatient) so now im doing other stuff like making forms for door arches etc while i wait.
                            I cant wait to get the floor on!
                            Justin
                            • Bandrasco
                              • Oct 2008
                              • 208
                              #29
                              Re: Justin Pompeii
                              Looks great Justin!
                              Bill,
                              Check out my build http://www.fornobravo.com/forum/f8/b...egin-5443.html
                              • nodoubt68
                                • Oct 2008
                                • 60
                                #30
                                Re: Justin Pompeii
                                Hi Justin, love ya work so far. I also like your design with your dual firewood boxes. Good luck matey, looking forward to watching your progress.
                                Cheers Lee
