Re: Dino's 42" Pizza Oven Starts
Thanks Mark, I've been reading others post on the homebrew mortar mix and I don't know which way to go yet. Did you use the Portland Cement home mix or did you have access to Calcium Aluminate?
And thanks John for the Heat Stop source list. Litterally NONE of them within a 3 hours of me carries it. But they did show me how to directly get it from the manufacturer however it's twice what I will need yet is comprabable in price to Refmix.
The nice folks at the Forno Bravo Store are working on a solution for me so I think I'll cut my next row as tight as possible to reduce joints even more and see how much Refmix is left. Maybe completely cut and dry-fit my chimney anchor plate and then I'll work on the not-so-sexy stuff like fill the little vertical gaps in my block stand with cement where I interspersed the 8" cmu's.
We've had 3, very dry just under 100 degree days so the dome is drying out nicely . Thanks everyone, Dino
I'm not a big guy, but I couldn't really do that more than once.
I did have to crawl in on my back with a brass bristle brush for my final cleanup, though. Not the most fun thing ever. Wear goggles and a mask. It rains nasty stuff down on you and you can't get away from it!
