Re: Dino's 42" Pizza Oven Starts
Dino, I see where it looks like you already cut and installed the angle iron. I tried a different approach using bond beam blocks. I installed them upsides down and placed rebar so that it ran up inside the side blocks across the bond beam blocks and down the opposite side. This made for the rebar (which is a tension member) nearer the bottom of the lintel (where the tension is). The rebar I tied up with tie wire so that it didn't sink to the bottom, not that it would since the legs (verticals that ran inside the outer blocks) ran all the way to the slab. I then simply blocked the open cells of the blocks with a piece of 2x8 cut to the proper width and length and used a layer of wax paper for a release film. I supported the 2 x 8 cut down with props at each end. It worked well, after all the span is very short. Since you already cut the blocks to accommodate the angle iron you could simply use the same blocking as I described.
Looks like you had a busy day! I too divided the space below the hearth slab with a support wall and made it into two storage areas.
Looking good!
Wiley
Looking good!
Wiley
and now you tell me it can do even more! I would have totally removed it and tried cutting free hand but it's too late now. And I think my angle grinder WOULD have worked had it not been used since the '94 earthquake repairs so the grind-disc would barely cut a cake let alone block. I'm putting much quality time and good money toward this so the least I could do is replaced worn blades and such on my hand tools. Word to the wise (or newbie).
It's just great.
