Re: Dino's 42" Pizza Oven Starts
Hi Dino,
Your oven looks amazing, I have been following your build over the past 6 months and love your workmanship.
I will be starting on my Chimney/Flue construction in the next month or so and am unsure whether to go with a full brick Flue or Stainless Flue.
If you could rebuild your chimney would you leave the design/throat size the same or make some amendments?
Hi Dino,
) I would go steel again unless the local brick yard had the right size clay pipe. I would ALWAYS-ALWAYS-ALWAYS build my vent-opening-flu-box the exact same size and way. Here is a pic again of the opening and how I did it. I THINK I could have been an inch shorter in 1 of the directions and still been fine, but it draws smoke so well. A clay pipe could mimic what I've done if installed properly. Mike (mfiore) did the clay pipe well, you check his photos out). Good luck, I'll check out your build to see how it goes, Cheers, Dino
and I cut the cobblestones in half and they are the perfect size now.
) at some time in the future. 2 rolls would have made me have to think about what I'm covering and be careful about it. Having 3 rolls made it easy.
