Dino's 42" Pizza Oven Starts
  • Re: Dino's 42" Pizza Oven Starts
    Hi Dino,
    Your oven looks amazing, I have been following your build over the past 6 months and love your workmanship.
    I will be starting on my Chimney/Flue construction in the next month or so and am unsure whether to go with a full brick Flue or Stainless Flue.
    If you could rebuild your chimney would you leave the design/throat size the same or make some amendments?
    John
    __________________
    My Oven Thread:
    http://www.fornobravo.com/forum/f8/j...-wfo-7911.html
    The difference between a successful person and others is not the lack of strength, nor the lack of knowledge… but rather, the lack of will power.
      Thanks John!
      Re: clay pipe vs double-walled steel. The double walled, insulation stuffed steel pipe (like a durateck I used) is simple, 1 piece, is already insulated so it doesn't loose heat but heats up inside and helps the draft. However it's expensive, it has to be delivered & I know 2 of us that sent it back 1-2 times because it got dented along the way.
      The rectangular clay pipe you cut in half at an angle and re-mortar after flipping 1 half, has a built in smoke constrictor (a good thing that accelerates draft): it's a big rectangle at the bottom and a smaller square at the top. Makes for great draft if IMO you have an almost equally sized vent opening (or close to it) to start with. It is cheaper but you really should wrap the base in insulating blanket.The work may be about the same when you consider mortaring in the anchor plate.
      In next oven (in my next life ) I would go steel again unless the local brick yard had the right size clay pipe. I would ALWAYS-ALWAYS-ALWAYS build my vent-opening-flu-box the exact same size and way. Here is a pic again of the opening and how I did it. I THINK I could have been an inch shorter in 1 of the directions and still been fine, but it draws smoke so well. A clay pipe could mimic what I've done if installed properly. Mike (mfiore) did the clay pipe well, you check his photos out). Good luck, I'll check out your build to see how it goes, Cheers, Dino
      My Oven Costs Spreadsheet
      My Oven Thread
        Thanks for your thoughts Dino,
        I guess I will have to decide shortly and see how I go.
        cheers
        John
        __________________
        My Oven Thread:
          I've been searching for the just the right outer arch finish for weeks and found a brick yard that sold cobblestone. I purchased 4 of these things (about 4-5" square and red or burgundy in color) and they seemed too big. I then pulled out my HF wet saw that's been gathering moss since I cut my oven plug. It still works and I cut the cobblestones in half and they are the perfect size now.
          I stacked a few without mortar to see if looks right. I'll have to go buy a few more now and once I mortar them in, I can go to town on the ovens exterior.
          My Oven Thread
            It's going to look great, Dino! Good find!
            Mike - Saginaw, MI
            Picasa Web Album
            My oven build thread
              I like it, but are you sure you don't want to use the whole cobblestone? Once you put the veneer on the oven, a little extra relief might look good.
              Either way, beautiful.
              Dave
              Album: http://picasaweb.google.com/fornososo/Pizza#
                Thanks Mike and Dave. I tried the whole cobblestone and it seemed too thick. After your message Dave, I went out tonight and measured since you made a good point. Cutting it in half still makes it 1/4" to 1/2" (occasionally about even since the facade stone is irregular) so I think they will have a little, but enough depth or relief to distinguish themselves from the facade stone.
                Thanks guys, -Dino
                My Oven Thread
                  Great choice, Dino. Can't wait to see it when it's completed!
                  John
                    Hey thanks John! Me too, it feels like watching paint dry to me so I'm sure it seems even slower to everyone else. I can't wait until we "Spring Foreword" and I have time during the week.
                    The stone I bought is called Italian Cobblestone and it's like colored granite all the way thru, so I don't know if it's really from Italia, but I'll pretend -Dino
                    My Oven Thread
                      Hey Dino,
                      I am also looking forward to PDT. It isn't any fun working in the dark.
                      The cobblestone arch is going to look awesome.
                      Eric
                        Dino,
                        Amazing work, man. I've just been through your pictures and the spreadsheet. It is incredibly helpful. It's a good thing Mike was handy with the camera or I'm betting the photos would have been pretty sparse. I've got to hand it to you, undertaking the whole project, nice finish. I've been down that road before, having built my own teardrop trailer from scratch, it ain't easy, but it is definitely worth it.
                        I've decided to have a mason do the actual oven for mine, since my anklebiters will keep me from spending the time on it I need to. I'll be starting quite soon, and will be much better prepared thanks to your work, so thank you again.
                        Greg Bohnstedt
                        sigpic
                        I'm not dead, yet! I'm feeling better.
                          This has been a great thread. Especially the pictures. I wish I had taken more pictures while I was building.
                            Thanks Neil and Greg. It has been a lot of fun documenting the oven.
                            Greg: I was afraid the spreadsheet might scare potential oven builders but it's always good to be prepared and know where you need to spend your money. And even though you'll have a mason do the actual work, it's a lot of fun to plan, prep and watch. Not to mention the best part: lighting a fire and cooking in it .
                            I'm going to sneak out of work early today and see how much decorative arch I can mortar with the longer daylight.
                            Thanks again, Dino
                            My Oven Thread
                              Hi Dino! Did you use 3 rolls of FB insulation? I have a 36" and was wondering if I could get away with 2. Thoughts? I will build an enclosure as well. Can't wait to start back again in a few weeks.
                              Dan
                                Hi Dan,
                                Glad to hear you'll be starting up again soon! I'll be looking forward to pics.
                                I bought 3 rolls. I used 2.5 rolls of FB blanket on the oven: 3-4 layers on top, 2 layers around the sides, some was also wrapped around the base of the vent and I used it to pack in the 1" gap where my vent went thru the roof to keep the heat off the plywood roof base. I have a few feet left over, just enough to stuff it into 2 oven doors (ya, right ) at some time in the future. 2 rolls would have made me have to think about what I'm covering and be careful about it. Having 3 rolls made it easy.
                                My Oven Thread
